Been looking though a lot of solutions. Fridge side is warm freezer side is cold. No frost on back of freezer. The duct to and from is clear. The fan at the bottom of fridge is working. While both doors are open small amount of cool air will come through when freezer door is shut no air comes through. I'm at a loss?
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
SOURCE: I have a Jenn-Air JCD2389G Side by Side
It sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem
Ok so heresomethings that I know the fridge has done this once before. It was unplugged for about a onth then got plugged back in and now did the same thing again? Any suggestions
