Question about Voyetra Turtle Beach Ear Force X1 Headset
My turtle beach x1 headset has a buzzing sound coming through the headset do you know how to fix it?
  • 1 more comment
  • jeffjeff345 Jan 03, 2009
    my x1 wont stop buzzing even wen its muted
  • Janowskiiii Apr 21, 2009
    Mine just started doing this today exact same thing. No I don't have my charge kit in. i thought it might be the controller but its not because i tried my other controller. THIS IS BRAND NEW JUST BOUGHT 2 DAYS AGO. im really pissed now. Please help!
  • Anonymous Mar 29, 2014
    We cannot pair the turtle beach X32 headset with xbox 360. We have followed the pairing instructions but it still won't work. Any suggestions?
Do you have your play n' charge kit plugged in? if so, then thats what is causing the buzzing sound
Posted on Feb 08, 2009
    New Friend:
I have the same ******* problem what the hell. Why does this **** hapen? i just bought them and now thhis **** happends. **** turtle beach.
Posted on Jan 04, 2010
    New Friend:
Try pointing the transmiter directly towards the left side of the headset. i had the same problem and while fiddling with the transmitter i found that it stopped buzzing when i pointed it directly towards the left side.
Posted on Nov 30, 2009
    New Friend:
I had the same problem with the x11s, try taking out the red "add in" piece from the back of your tv and leave just the white in. Both game and voice chat worked after and the buzzing was gone.
Posted on May 05, 2011
6ya staff
SOURCE:
When I talk, my friends complain of a high pitched buzzing. I'm using the Turtle Beach X11 via a wired controller on the Xbox 360.
Same issue here. Can hear the high pitch buzz, and friends complain about it.
I have 2 Turtle Beach X11 headsets, and 3 Xboxes (std, Elite, slim)
Unplug the mic, and no high pitch buzz. Plug it back in, and its back.
Tried all 3 boxes experience same issues
Playing with volume and mic settings doesn't make a difference.
Would love to have a fix for this :-)
Dec 25, 2010 | Voyetra Turtle Beach Turtle Beach Ear...
My turtle beach X11 has been playing up for a few hours i could only hear through one ear cup i started to freak out and then even worse the other ear cup kept playing only every ten seconds and also this...
To test the headset, connect it to your PC and listen to some music. Use the green plug and USB. If both speakers work and it sounds fine, then there's nothing wrong with the headset.
Why don't you contact Turtle Beach directly for help?
Jul 27, 2010 | Voyetra Turtle Beach Turtle Beach Ear...
Turtle Beach x1's make an annoying beeping noise
If you're using the Play n Charge kit, then you might be hearing some buzz/whine through the USB power. Use the X1 without the Play n Charge. Does that help?
If you unplug the chat-controller cable from the X1 volume control box, can you now hear shots and explosions without the annoying beeping/buzzing noise? If so, then you may have a bad chat-controller cable, and you should have it replaced.
Mar 05, 2010 | Voyetra Turtle Beach Ear Force X1 Headset
I have the x1 turtle beaches plugged in but i cant hear anything. There just isnt any sound coming out except for a little buzzing.
Try the X1 on your PC or laptop to check if it's working OK. if you can hear fine on the PC, then there's nothing wrong with the headset and you should check the XBOX connections or RCA splitter cable.
Feb 17, 2010 | Voyetra Turtle Beach Turtle Beach Ear...
Buzzing noise coming throught my headset on my turtle beach x1 headphones
Check if the buzz stops when you remove the talkback cable. If so, then try a wireless controller if you're using a wired one. Also, don't use a play and charge kit because it causes a lot of buzz on the headset.
Jan 16, 2010 | Voyetra Turtle Beach Turtle Beach Ear...
My turtle beach headset is buzzing on the left side
If you plug the X1 USB plug into a USB port on a laptop instead of the USB port on your Xbox, does the buzzing go away? If yes, then an AC-to-USB power adapter should fix the problem for you.
Dec 28, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
My turtle beach x1 wont turn on?
The green light (or red if it's muted) should glow on when you plug in the USB. If it doesn't, it means there's a problem with the power feed to your X1 and you should contact Turtle Beach tech support to get it fixed.
Aug 07, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Buzzing noise when I talk
Do you have the Play n Charge Kit connected? It seems if you use that with the X1 at the same time, some kind of hum noise is transmitted through the USB bus power to the X1 headset, and you hear a buzz or high-pitched hum. The solution is to use the X1 without the Play n Charge Kit, and charge the controller when you're playing the sound through your TV instead of the headset.
Jun 29, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Voyetra Turtle Beach Ear Force  X1 Headset Logo
4,799 people viewed this question
Top Voyetra Turtle Beach Radio Communications Experts
Ekse
Michial Gueffroy
Greg Ulan
Are you a Voyetra Turtle Beach Radio Communication Expert? Answer questions, earn points and help others
