Question about Sennheiser HDR 120 Consumer Headphones
Sennheiser TR 120 Headphones
I have just returned from a 4 month holiday and my Sennheiser TR 120 headphones are not working through my Receiver. I have tried to isolate the problem by disconnecting the power and the leads from all components and they still are broadcasting the ABC or SBS depending on just where I tune them. Can you help solve please??
  • Helen Turner
    Helen Turner Sep 20, 2012
    Thanks for your help everyone. Looks like it may have had a bad connection to the main unit. My husband pulled it out and put it back in, had to press it in really hard and now it all works. So that may have been the problem!!!!. Or there was a gremlin around giving me the irrates. Thanks again all and cheers.
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Sennheiser TR136 Wireless Headphones Nothing Happens
I had a similar problem - after owning them for 4+ years, no sound we coming out, and no beeps -- nothing. The lights on the charger stand were on though.
I tried buying new rechargable AAA batteries and they were NIMH (nickel metalhydride?) and still didnt work. I borrowed a friend's pair of NICM (nickel cadmium?) AAA rechargables though and the problem was solved!
So, it would seem the some of the new chargable battery types might not work in older models of this unit (which is also called the RS 130 now in the US and Cdn web sites).
Hope this helps!
Posted on Mar 18, 2009
JustPatrick
  • 7 Answers
SOURCE: No sound coming through my Sennheiser wireless headphones
Turning the transmitter on and off (Fig. 5)
Turn on the sound source. This automatically activates the
transmitter and the green LED “ON/OFF” lights up. If the sound
source is turned off, the transmitter is automatically deactivated
after approx. 3 minutes (the LED “ON/OFF” goes off).
Note: The automatic level control only functions if the volume of the
sound source is sufficient.
Posted on Apr 02, 2009
Anonymous
SOURCE: sennheiser hdr 120 headphones no longer hold a
Twist the pad counterclockwise on the left earpice. You'll find the batteries underneath.
Posted on Mar 06, 2010
Anonymous
SOURCE: WHERE DO THE BATTERIES INSERT?
There is a small arrow on the plastic. Rotate the ear pad counter clockwise.
Posted on Apr 05, 2010
How do I get sound to my Sennheiser RS120 wireless headphones when it shows as working properly?
Dirty volume control on headphones. Try moving the volume control back and forth several times to clean off the contacts.
Dec 14, 2014 | Sennheiser RS 120 Consumer Headphones
No power sennheiser rs120
Probably a defective item, Try for a return.
Oct 13, 2014 | Sennheiser RS 120 Consumer Headphones
I have Sennheiser 120. Set it up right. One side or the other comes in clear. Never both sides at the same time.
I have a set as well but the batteries were weak and it was doing the same thing when they were new. Replaced with good batteries and that was the problem. if you try this and they still don't work then just return it for a replacement
May 17, 2014 | Sennheiser HDR 120 Consumer Headphones
We have purchased sennheiser RS 120 wireless headphones but find our LG tv model 32LS3450 - TA does not have audio out, is there a solution?
Your TV should have Audio out somewhere, even if its digital audio out, you could output to a receiver and then hook your headphones to the receiver.
Oct 13, 2013 | Sennheiser RS 120 Consumer Headphones
Sennheiser 120 green light goes off
Can you remove the rechargible batteries ? To try and reset them ? Or maybe replace them ? It sounds like the batteries have gone bad and not charging
Nov 12, 2017 | Sennheiser HDR 120 Consumer Headphones
Sennheiser HDR 130 with TR 130 transmitter not working.
If you twist the earpiece,one of them has two NIMH AAA batteries ,worth checking out if these are gone ,which is what happened to me.I was about to bin my rs130's and just stuck two new rechargeables and the earphones are working again!!!!!
As for $20 dollars from sennheiser for replacements!?!?!?
You should pick up two NIMH batteries for a couple of bucks on ebay or amazon.DO NOT USE ORDINARY BATTERIES!!!!!
Feb 09, 2012 | Sennheiser HDR 130 Consumer Headphones
After hooking up a HD receiver from my cable company the headsets no longer work.
This would seem to be more a function of the device to which you connect the headphones than the headphones themselves. Can you flesh out the details? There may be a setting you're unaware of.
Mar 06, 2011 | Sennheiser HDR 120 Consumer Headphones
Sennheiser RS126 headphones/base stopped working
Broken audio cable entering the transmitter or audio jack plug.
Power supply plug loose / faulty power supply.
Nov 10, 2017 | Sennheiser RS 120 Consumer Headphones
WHERE DO THE BATTERIES INSERT? SENNHEISER TR 120
Oct 09, 2009 | Sennheiser Audio Players & Recorders
Sennheiser HDR 120 Consumer Headphones Logo
693 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Geoff
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
