Minolta Dimage Scan Elite II Film Scanner Logo
Rodger Fowkes Posted on Apr 20, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Scanning problems please help me i am trying to scan 35mm slides in my scan dual 2 for a picture library they want me to create a 300dpi 48-50mb tiff file 8 bit 11inch -16inch image.My scanner will not let me go bigger than 13.44-8.96 inches is there anyone who can help me ?.
Anonymous
Level 3:
Genius:
  • Master 2,985 Answers
  • Posted on May 28, 2007
Anonymous
Master
Level 3:
Genius:
Answers
2985
Questions
0
Helped
1028243
Points
5636
The scanner will only do what it is made to do thats its biggest.
1helpful
Scanning 110 Instamatic slides on Epson Perfection V700 photo scanner
Hi Stanley - does this youtube video help? http://www.youtube.com/watch?v=EcALdbbCnSk
If not, let me know and we can investigate further.
Regards,
Justin.
I have been using the Konica Minolta Dimage Scan Dual IV for the last 2 months and i've scanned about 350 slides, so i know it works. however sense yesterday afternoon it hasn't been working for me. I am...
I do not have an answer for you, unfortunately, as my Dual Scan IV is doing almost the same thing....my unit will not load the 35mm film slider - when it tries to load, it makes a fairly loud clicking or ratchetting sound. This occurs each time I push the film into the unit. Have you had any replies or have you found a solution to the problem. Thanks and good luck.
1helpful
How to scan slides with Visioneer 9520 USB Scanner - it scans who
I have successfully used my Visioneer 9520 to scan 35mm slides, and they came out perfect. To do this, in my image editing software, I select File/Import/Acquire/Visioneer ScanManger Pro. This opens the VIsioneer scan manager window, where I select "Scan 35mm using:" and then I choose the desired scanning configuration, e.g., "35mm Better, 35mm Best, Custom" etc. See image below.
BTW: After several moves, I have lost my 35mm scanning template. Do you know where I can get another one, or do you know someone who could actually scan theirs and email the image to me? I could then create a duplicate from heavy black construction paper or card stock.
32helpful
Setting PDF as default scan setting on Canon Imagerunner 3035
Additional Functions (hardware button on the panel)
Communication Settings
TX Settings
Scroll down to 2nd page
Edit Standard Send Settings
File Format: PDF
Scanning Mode: Black 300dpi
1helpful
Scanning 35mm slides and saving to computer
In order to scan 35mm slides to your computer, you need a scanner that has the capability of doing this. These scanners will either come with a 35mm adapter that will allow you to scan the slides, or there are scanners that will scan only 35mm slides. A good recommendation is either this or this.
Thanks and please take a moment to rate as fixya.
2answers
Scans slides too dark.
maybe the slides are too dark, in other words, the pictures you took didn't have enough exposure therefore you it shows up dark.. You could always use photoshop or someother photo manipulation software to lighten the scan, same thing happens with my hp scanner with slide adapter, if it slides just show up dark, lightening it with software will help, unless it is unsaturated/shadows too dark, etc..
Hope this helps.
Trying to scan document on HP Deskjet F4200 all in one series. When scanning small document from TIFF Image this is scanning through as 25.5 MB so I am unable to send this as an attachement to an email as...
Try lowering your scan resolution settings. Magazine quality is 300dpi. If you don't want to lose too much quality, open the file is a image editor and crop only the area you wish to send.
60helpful
6answers
Minolta DiMage Scan Dual IV
1) Install all of the usual Minolta software in Vista.
2) Create a new folder somewhere
3) Create a new txt file named minolta.inf and paste this into it:
; scanners.inf -- Test Vista Minolta Film Drivers
; To remove this driver and install the original
; manufacturer's driver, go into Device Manager,
; open Imaging devices, then click on the scanner name
; with the right mouse button and choose Uninstall.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=3/12/2009,2.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB scanners
"Minolta Scan Dual II" = USBScanner,USB\Vid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USB\Vid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USB\Vid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USB\Vid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USB\Vid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USB\Vid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USB\Vid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USB\Vid_0638&Pid_0a16
;---------------- Duplicated from [Models]
[Models.ntamd64]
; USB scanners
;---------------- USBScanner -------------------------
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[Strings]
Provider="Konica Minolta"
Mfg="Konica Minolta"
4. Save file. Turn on scanner and go into device manager and update the old minolta driver with this driver. You may have to manually update it.
5. All the normal Minolta programs now work just fine. Enjoy!
Scanning sheet music
Scan all pages with GrayScal Single Page JPEG and then convert them to Multipage PDF.
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
