Printing from Adobe, Word or Excel, when try to print it kicks you out of what ever software you are in. Also if it is your default printer it will not let you open the Excel, or Word again Change default printer is work around. Same problem with 2 users on 2 different pc's.
SOURCE: printer won't print
Make sure the ready light is on. Press the green go button.
Also make sure you don't have printing paused.
CONTROL PANEL
PRINTERS AND FAXES
DOUBLE CLICK ON YOUR KYOCERA PRINTER DRIVER
CLICK FILE
IF THERE IS A TICK NEXT TO PAUSE PRINTING, THEN CLICK ON PAUSE PRINTING
IF NOT THEN DON'T.
ALSO MAKE SURE YOUR PRINTER IS SET TO DEFAULT PRINTING DEVICE.
If all else fails, install the kyocera fs-1700 driver for the printer. it's a generic driver for kyocera-mita.
SOURCE: Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Resoloved... Removed driver and printer from server. Added printer back using a different universal driver and updated settings.
