SOURCE: Xerox Phaser 3100 Printer Error Fuser Temp.
fuser Temp printer error problem.please give me the solution.
SOURCE: fuser temperature error for xerox 3100mfp
kindly check externally the fuser is heating or not. i SUSPECT THE FUSER MIGHT BE FAILED.
SOURCE: i have blocked the fuser uit
All you have to do is open the fuser unit on the end (2 Screws) and you will find a fuse which has 3 strips (in a plastic casing with wires attached). You must the solder the strips so that they are joined, and that should reset the fuser.
SOURCE: printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
