INTERFERANCE FROM NEXT DOOR HOW DO I CHANGE CHANEL
Open the back of the door chime and the button press.
On the back of both of them there is a set of jumpers.
From left to right there are 6 available frequencies. You need to grab to jumpers to join 2 of the pins together (top and bottom pin). If you don't have a jumper just use a set of pliers and cross the 2 pins together (top and bottom pins) on a channel you wish to use. Repeat the process for the button press if you've just done the door chime. The 2 pins that you've joined together needs to be the same as you've just done for the door chime.
Note the red jumper on the button press, selects the type of door chime you want to hear. this is the 4 right hand side pins on the button press. The far right is a long chime and second in from the far right is a shorter chime.
Hope this helps, figured it out by trial and error. :)
Thanks Shane, I can't access the 6 frequencies just 2 by changing the jumper on the door press. This gives me either a long tone or the shorter tone using the last 2 pin settings on the right hand side. I've laready tried moving the jumper on the door press but no other sounds are audible. What ami doing wrong?
The last 2 pins are for sound, short or long. The other pins are for the frequencies, by that i mean channels. They need to be the same on both the remote and the door chime.
Hi Shane, I am having the same exact issue. Crossed pins 1and 2 separately on both button and unit. Chime worked okay but the unit still picks up a false signal. I am wondering where can I get jumpers from as crossing the pins you cant see if they are contacting or not.
Hi Robert, You can buy the jumpers online. What your looking for is the following:http://www.ebay.com.au/itm/25-x-Standard...
