Error 70 on Brother printers usually means the encoder strip behind the carriage assembly is out of position or very dirty. I would remove the top cover to correct the error and/or you might also find a scrap of paper either on the extreme right or left stopping the carriage from moving properly.
Brother Printer Support
The machine has a mechanical
problem.
-OR-
A foreign object such as a clip or
ripped paper is in the machine.
Open the scanner cover and look on the left,
middle and right hand side under the covers for
foreign objects and paper scraps. Then, disconnect the
machine from the power for several minutes and
then reconnect it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Dirty encoder strip
Foreign object, such as a paper clip or ripped piece of paper is stuck in the
machine
Mechanical malfunction
The
most common cause of this issue is dirt on the encoder strip.
