Usb device not recgonized
Did the keyboard come with a cd?If so(which it usually comes with),put the cd into your drive and it may just run the drivers.If nothing happens,leave the cd in the drive and go to control panel/install new hardware tab in the control panel.Then it should display a list of programs on your computer with a question mark next to it to describe that it is not running correctly(make sure the keyboard is plugged in when you do this).Click on the line that says your keyboard or it may say something along those lines...Then it will opt you to use the internet or install the program manually.Select manually and it should search for the driver,and if your cd is still in the drive,it will find any driver on said cd and install it so your keyboard will work.
Any of these keyboards usually come with software anyways,so it should be on the cd.If you dont have one:look up casio on google and see if you can get the drivers from their knowledge base.
