While having my satellite rca cables plugged into my AV1, I am unable to plug-in other rca cables (nintendo-wii cables, etc...) to other components. Basically, I have to take out the satellite rca's and replace with whatever I am wanting to watch/do. Any suggestions??
You need to get a device call a composite video switch box. You plug allof your devices in the inputs on the box and then the box uses cables to plug into the TV. You then just use the switch box to select the video sound you want to display. The switch boxes are available in manual and remote and you can get them from Amazon.com
I hope this helps,
BuddyMc
SOURCE: Component 1 and 2 audio inputs function poorly or not at all
They get old and get dusty, and with people in the house, things get stuck in those holes that shouldn't be. Try cleaning it out with some dust spray.
SOURCE: 50" Vizio Plasma reads "No Signal" on all inputs?
Well, your TV is still under warranty. That's the good part.
The only thing I can recommend without voiding the warranty is leaving the TV unplugged for 30min. That way, the TV can reset itself and hopefully correct the problem.
If that doesn't solve the problem, it's time to use the VIZIO warranty.
Here's contact info if you need it.
Technical Support
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
[email protected]
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
SOURCE: Need to hook up WII
Wii system dosen't take RCA component cables connections.Go to walmart,if those clecks willing to help u talk to them tell them u need a Wii system cable connections wire they'll point u to what to buy.Or better custmer serviced go to Best Buy problems is a bit more exspensive there.Tries websites like Amazon.com,Ebay.com u can buy it from there too.
