SOURCE: Sound Problem
ok paola! the problem is the headphone connector inside the TV.. maybe did not turn back the switch to speaker mode. check the headphone connector (at inside the tv). small problem goodluck paola!!!
SOURCE: When I disconnected my Headphones
Usually there is a nut on the back that hold it in place. If you can solider replace the jack. There are three contacts on the jack, one is ground, one is audio and the other is the speaker. If you know your way around tyou can jump the audio and speaker wire together and sound that way.
Tom Miller
