your system is over charge with refrigerant gas thats why its frosting inside and outside of your frige.....you must call a technician to decrease the charge of your system
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
the thermastate in the frig compartment controls when the compresser comes on,it turns the compresser on at 38 degrees and off at 35 degrees,if the temp goes below 35 degrees the thermastat will no turn the compresser on.to save the food in the freezer you could of put the food in a trash can and put it outside.
Your owners manual , will tell you the minimum clearences for the refrig . If I have 2 refrig's on my test line , less than 2 " apart , both will emit moisture on the sides , depending on the weather . There has to be air flow on the sides and rear . Sorry this doesn't answer your question directly , but there is no product that can be installed , to stop this problem with the refrig . However , you may , pull the refrig out , and treat the faceing wood , with a waterproof paint or sealant . It sounds like this part of the cabinet , will not be seen . Plastic will not work , moisture will just go thru it . Yes , treating the faceing wood sounds like the most logical solution .
Look inside the refrigerator section for a switch that says high moisture or energy saver . Some units allow the door frame heaters to be turned off during times of the year when the humidity is low.
HI thanks for the question. the heat around the cabinet and doors is normal . the heat prevents moisture from hitting a cold surface, and turning to water , which would cause water to run down the sides, rusting the hinges. thanks the appliance doc. please rate my answer. thanks.
Heat exchangers for rejecting heat to air are built into the outside walls. This is normal. Just make sure you have enough clearance for free air circulation around it.
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing,
check vents in refrig. make sure no blockage, freezer control should be in the middle setting,
you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
whats the brand and model number
Dimensions of ABB2527DEB
