I don't have a parallel slot on my cpu so bought a parallel to usb interface cable still can't print plz help
SOURCE: can print correcly
plz check all the settings, language setting must be check , after that if the problem not solved then uninstall the driver and again reinstall the printer driver
SOURCE: my epson LX 300+ was already installed but will
First, you must install the driver of lx-300+. open control panel, printer n fax then find epson lx 300+. Don't forget to test what port that your lx-300+ support. LPT1. Then print test page...If your printer run... it's finish... you have succses instal the printer...
SOURCE: can not print with Epson LX-300
The USB to parallel converter does not always work.
You should buy a Parallel port for your computer if you have can extra slot inside the machine. The cost for the parallel port is usually under $20.
thanks adi
Testimonial: "Yes that can be done but you have to have extra slot.So I wondered if some software would do the trick.Otherwise your solution is the only way! Thanks"
SOURCE: i have epson lx 300+
You can install a parallel port adapter on you computer.
This WEB site has parallel port adapters that suit your computer.
http://www.ieci.com.au/products/product_list.asp?class=3&basecat1=50
Since you did not provide details of your computer I cannot advise you exactly what adapter you need, but you can select or ask the supplier the correct one for your computer.
