Kenmore 659 Electric Dryer Logo
Posted on Dec 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will not start
Kenmore elite-oasis -check lint screen come on remove and clean,
Reinsert and still will not come on.
Kristin Farren
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 29, 2016
Kristin Farren
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
114
Points
We just had the same problem. No error code. It would run for less than 2 seconds then shut off. We had a Sears repairman come out and we found out the wiring in the house we just moved in was not right.
Service repairman checked the dryer thoroughly and found no problem with the dryer. Then he checked the outlet and found line for heater was 122.4 V and line for motor 244.8 V and needed to be 120 V.
Electrician came out and dryer is working fine again.
Allen Neal
Level 2:
Sergeant:
  • Expert 359 Answers
  • Posted on Dec 30, 2008
Allen Neal
Expert
Level 2:
Sergeant:
Answers
359
Questions
Helped
189087
Points
623
Check breaker or fuse and be sure you have 220 volts @ dryer with volt merter
Kenmore Elite HE5 Steam dryer F30 code. How do I clear the F30 code.
Several possible fixes:
http://www.fixya.com/support/t1225051-kenmore_elite_he5_error_code_f30
Quoting:
"F 30 code can be reset by un plugging power cord for 5 minutes also pull out the detergent dispenser and reach all the way in to the back there is a small plastic flapper valve move it from side to side with your finger this will rest code f30 and save a tech visit.."
https://removeandreplace.com/2016/01/18/kenmore-elite-dryer-error-fault-codes/
Kenmore Elite Dryer Error Code = F30 Error Condition = Restricted Outlet Airflow
Check or Repair Needed = Check the lint screen filter and clean of any lint. Remove fabric softener buildup on the lint screen if necessary. Clear lint blockage restriction from the air vent exhaust system.
https://www.shopyourway.com/questions/1125417
Lint cleaning
http://www.fixya.com/support/t25862220-error_code_f30
What is error code F30?
Kenmore elite oasis st dryer - has power but won't run. Thermal fuse is NOT where I expected from videos I have watched.
Posted by Tom berwick on Sep 13, 2015
The F30 code is a false code. It does not mean anything. The dryer will work fine. When I worked for Whirlpool, this was a programming issue. I owned the same dryer. It displayed this code and engineers explained this to me. The dryer worked fine.
How to clean lint out of inside of Kenmore Oasis Elite dryer
Here is a "youtube" video showing how to take the dryer apart. Right around 3:20 is where you need to take the plactic cover off to be ablwe to clean all the lint off.
Kenmore Elite Oasis 6806 Electric dryer with burning smell
you must disassemble the unit and clean the lint out of the heating unit area, it is lint catching fire and could be dangerous to continue using your unit in this condition. a vacuum cleaner should do well to clean the lint and the drum must be removed to do a proper cleaning
Sears kenmore elite oasis dryer 110 67032600 check lint screen flashes doesn t heat
Check the vent on the back. This is indicating a air flow issue. If the vent is clear ohm the heater out check it for continuity.
You can watch a video that explains how to complete this repair on your sears Kenmore Elite clothes dryer at the link below.
Sear Kenmore Dryer Video
Dryer stopped and said check lint screen
There is a lint screen,usually on top of the dryer, that pulls out to remove the lint,it is probably stopped up.
I just bought a kenmore elite oasis top-loading washer. It was a floor model-i didn't get the manual. Does it have a lint trap and how to I empty it? Thanks.
You must remove the inlet hose to the pump to find the screen.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Check lint screen come on
Check the tubing the lint goes through (exhaust). This may be stopped up or clogged. There is a build up here of heat or something that is preventing proper air flow.
8helpful
3answers
Kenmore Elite Oasis Dryer with Airflow problem
same problem removed back cover cleaned lint found pulley had unscrewed and belt was off.installed pulley rev threded and put belt back on.
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
