Heat
See the causes, and proceed. God bless you It is possible that your dryer isn't
heating because its heating element is defective. Heating elements are
irrepairable. If yours has ceased to function properly, you will have to
replace it. Open your dryer's cabinet and locate the heating element so
that you can test it. hermal Fuse
Another possible cause for a dryer not
heating up could be attributed to a faulty thermal fuse. Once a dryer's
thermal fuse has blown, it is no longer of any use. If your dryer's fuse
is blown, you will have to replace it. Open up your dryer's cabinet and
locate its thermal fuse so that you can test it. If any of your dryer's thermostats have
become defective, they could be the reason that your dryer is not
heating. Open up your dryer's cabinet and test each of your dryer's
thermostats. If any are faulty, replace them. Timer motor
A defective timer motor could also
cause your dryer to not heat up. Test your dryer's timer motor. If it is
no longer functioning as it should, replace either the entire motor
assembly, or just its motor.
f your dryer won't heat up, it's possible that it is not being supplied
with the proper voltage. Here are three ways to make sure power is
getting to your dryer: First, make sure your dryer is plugged in. Next,
check the circuit breaker panel to make sure all the circuit breakers
are in the correct positions. Finally, check to make sure no fuses in
your fuse panel are blown. Any of these could explain why power is not
getting to your dryer.
Heating Element
Thermostat
