Mitsubishi WD-82837 82 in. HDTV DLP TV Logo
Anonymous Posted on Sep 22, 2012
Wd-82837 status light blinking tv tries to turn on blue sreen comes on then tv shuts off.
re31512
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 12, 2014
re31512
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
528
Points
My status light is flashing and I cannot get an indication that the TV is actually on. There is no sound. I cannot get any display whatsoever. The blue light across the bottom is not on. Thus, the TV is probably on in the 1st place. Ideas?
5 Related Answers
Anonymous
  • Posted on Oct 23, 2008
SOURCE: yellow status light on mitsubishi wd-65733 tv
When tv goes out, press the menu and input buttons. The green light will flash with a 2 digit code.
Anonymous
  • 233 Answers
  • Posted on Dec 19, 2008
SOURCE: STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
turn the tv off, hold down device and menu buttons on the front for 5 seconds, you will get a code flashed out through the LED's.. the codes are as follows:
12   No error detected 22   Recovery from momentary Reset 32   Lamp Cover open 33   Air Filter Cover open 34   Lamp abnormality 35   Chassis Fan failure 36   Exhaust (Back Cover) or Lamp Ballast Fan failure 37   Engine (DMD or Lamp) Fan failure 38   Excess Lamp Temperature 39   Excess DMD Temperature 41   Short Detected 44   DVI Cable (between Chassis and Engine) disconnected
Anonymous
  • Posted on Jul 16, 2009
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Anonymous
  • 5138 Answers
  • Posted on Feb 15, 2010
SOURCE: I have a Mitsubishi WD-52327.
Replace the Lamp P/N 915PO20010 if it has never been replaced.
Mats Electronics has them for $99.00 1-800-628-1118
Anonymous
  • Posted on Sep 10, 2010
SOURCE: Red blinking status light on DLP Mitsubishi TV
how do you get the tv back on when the light keeps flashing
My mitsubishi wd 82837 tv has a flashing red status light; what is wrong with my tv?
Well...it could be a lot of things, how many blinks does it get before pausing?
Mitsubishi tv WD 82837.turns on for about 30seconds, then shuts down with a red blinking light
Can you try this and post the result(s) here?
- When the TV is OFF, Press & Hold the "Power" button for a bit more than 30 seconds. Please post the result here...Thnx
How to replace power supply board on wd-82837
How do you know it needs one ? That sounds more like a lamp, color wheel or DM module issue (if set uses one.)
Mitsubishi WD-73638
lamp is gone needs replacement
1helpful
I have tried to turn my television on and the status light blinks for about a minute, you can hear the TV try to start up and then the whole system shuts down without anything actually powering up. Also...
Unplug the tv for about a minute - plug it in and press the reset button on the front of the tv - hold it until the light blinks. The set should come on in a minute of two - if not try the same routine again.
I have a mitsubishi the model number is wd-82837 it keep shut down after blue screen show
Ur tv"LAMP"LED light indication flashes or stay on?Ur tv projection lamp been inside this tv like a 1 1/2 or 2 years and tv been on an in used like 4 or 5 hours every day.Yes to all of this,than the tv projection lamp is the causes and it life are ending.The tv projection lamp require replacing.
2answers
Green status light FAST blinking and does not shut-off.
SORRY, NO ANSWER.>>> AFTER TURNING MINE OFF FOR THE NIGHT THEN BACK ON IN THE AM, STUCK ON THE WELCOME BLUE SCREEN W/BLINKING GREEN LIGHT BESIDE THE POWER BUTTON. TRIED HOLDING DOWN THE POWER BUTTON FOR 10 SEC., BUT ALL IT DOES IS SHUT OFF. I CAN NOT GET IT TO PERFORM SYSTEM RESET. PLEASE HELP, IF YOU FOUND A FIX FOR YOURS. THANKS! please EMAIL ME AT [email protected]
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
