My remote wont change to a different input
SOURCE: I changed the batteries in
Try this site I believe it will help you a lot..Just click the link..Hope it will help you..
SOURCE: i have a haier tv
allday70, we don't have any current codes for a Haier TV, but we can definitely check it out and help you get that programming.
As there are no codes for that TV, I would recommend trying a power scan. I have posted the steps below, though you can view this link: http://www.dishnetwork.com/SupportSection/remote-setup for general information on setting up remotes.
Power Scan to TV:
1.) With the TV on, press and hold the TV button (about six seconds) on top of the remote until all mode button backlights come on, then release.
2.) Press and release the red power button, then press the Up button once a second while pointing the remote at the TV. If the code for the TV comes up, it will power off.
3.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works try several different functions for that equipment.
Let me know if you have any questions or need further assistance!
Tommy Faust
DISH Network
SOURCE: my rca universal remote won't change the channel to video mode
GO TO BESTBUY AND GRAB A REPLACE FOR LESS THAN $13
Most RCA sets use a
four digit code to control the v-chip. The code reset is different depending on
the model. Try each number until you find the one that works for you.
1.
Hold down the
MENU button on the remote and VOLUME DOWN button on the TV it's self at the
same time for at least 4 seconds. The set won't say so, but the lock will be
unlocked
2.
Hold down the 0
(zero) button on the remote and the VOLUME DOWN button on the TV itself at the
unlocked
3.
Hold down the
MENU button on the front of the TV and the TV button on the remote at the same
time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU
button on the front of the TV at the same time for at least 4 seconds.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
