Some Roblox players report that every time they try to join a friend, they get the error code 106. The error is reported on Xbox One and usually occurs for people who first try to join an online session. Read blog for solution
Error 106 is a typical blunder experienced by windows users. Appears generally because of Misconfigured, harmed or corrupt system files on the PC, this is certainly not a common error. Notwithstanding, investigating this blunder is imperative to keep any undesired burden under control.
To not get this error anymore, Scan the corrupt files in the system and remove them from the system.
The answer is in the question - you've been disconnected for some reason.
Are you wireless or wired?
if you are wireless then try going next to the wireless router to see if the fault is being too far away.
get back to us with a bit more detail
You can solve this problem by temporarily unistall or pause your Antivirus when connecting.
(Remember to Rate) Sounds like a few things, but lets get most of the problems out of your way. So you want to...
The answer is in the question - you've been disconnected for some reason. Are you wireless or wired? if you are...
it is an antivirus problem... uninstall or pause your antivirus and then try to connect.it will definitely work..this is due to the wrong connections from chrome with antivirus..
Look in Start - Connect to - Show all connections - If you have an Internet Gateway and the Internet connection shows disconnected - Double click the line and it will connect.
Now if I could only work out why it doesn't do this automatically ....
Also Use Internet Explorer to connect to http://192.168.1.1/ which should allow you to log into the router directly and set the log on details and logon password.
