Canon PIXMA MX310 All-In-One Printer Logo
A
Anonymous Posted on Sep 23, 2012
My printer is only pulling the paper in from one side, have tried cleaning the rollers and have checked for foriegn objects in the paper feed, display reads no paper, any ideas?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Sep 23, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
746
Points
My problem too, solved it easy, couldn't believe it, a pen had fallen in the paper feed slot, I didn't think it possible, couldn't see it until I took it to bits, be careful but worth a look
5 Related Answers
Anonymous
  • Posted on Apr 10, 2008
SOURCE: paper feed issues
Yeah i tried the cardboard as well...it didnt work first time. but as i had no other choice, i did it 2-3 more times and eventually i heard a lot of noise and to my surprise my mailbox key popped out covered in ink...
so the cardboard seems to be the magical solution. not only does the printer work again but i also found my key!
Ajkill
Anand Kumar
  • 2035 Answers
  • Posted on Jun 12, 2008
SOURCE: Canon i9950 feed issues
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button.
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Anonymous
  • Posted on Oct 22, 2008
SOURCE: Paper Feed Problem
Hey I had this problem too for about 6 months. Just press the "Feed Switch" button under the main display to switch it from feeding from the tray under the printer.
Anonymous
  • 8637 Answers
  • Posted on Jan 29, 2009
SOURCE: Paper not feeding into printer: pulls to the right and jambs
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
banfixa
  • 14 Answers
  • Posted on Jun 13, 2009
SOURCE: Error E3 when no paper jam
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Paper misfeeding on one side but printer keeps printing with no paper
Look for any foriegn objects or old torn paper from an earlier jam. Something is either obstructing or mis-guiding the paper. If nothing is found, use a can of compressed air to blow thr paper intake area out, then test print again.
If still not solved, use a cottom swan soaked in alcohol to scrub clean the rubber paper pickup roller. Over time it gets slick from paper dust and the paper will notget grabbed evenly, causing it to skew as it's pulled in.
10helpful
2answers
My epson stylus t13 have a problem general error... foriegn objects into my printer... i have opened my printer to see what foreign objects but theres no objects or paper in the rollers side and in the...
Hello there,
This is called a false paper jam. normally, a reset is required for this.
Hold the power button for 30 seconds and this should prompt a shut down.
next, make sure that the rollers are clean inside. use a lint free sloth and some distilled water. Dampen the cloth (Q-tips works fine too, please do not use cotton) and rub the rollers.
Then as it dires up. turn the printer on and do a test page.
Please don't forget to leave a feedback and testimony if it works.
3helpful
2answers
My canon printer/copier does not feed paper in machine. makes all the sound but wont feed. help
1. Try cleaning the paper feed rollers
Instructions how to clean the paper feed rollers.
If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
    Remove all sheets of paper from the rear tray, then click 'OK'.
  4. Confirm the message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
  5. Confirm the message, and click 'OK'.
    After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  6. Confirm the message, and click 'OK'.
    Note: “Feed roller cleaning is completed” message is displayed when the paper is fed and ejected.
    Click 'OK'.
Roller Cleaning is completed.
2helpful
2answers
Paper won't feed into printer. Always gets jammed
you must have objects foriegn objects inside your printer. i.e. paper clip or some other object . Get your printer and move it side to side see if you can here anything moving about. once its out then perform alignment of rollers using epson maintenance menu.
HP OJ 6310 - scan/fax feeder won't pull through paper for scan/fax. Have tried cleaning rollers to no avail. Can you help??
There are two types of jams.
Physical, A physical obstruction is preventing the paper from gettin through.
Timing, the paper does not reach a given piont in a given period of time.
Physical jams can be the easier of the two, look for anything out of place, check the lead edge of the paper, is it dented or damaged? if so line up the damage with the feeder open and see if you can locate the problem, it does not need to be a foriegn object, it could be a guide mylar that is damaged or out of place.
Timing are are where the original does not show any signs of damage, the machine just stops.
This can be caused by feed tires, feed motor or clutch, or sensors,
Check the condition of the rollers, rollers generally have a rippled surface, if the rollers are bald and or have become concave. they are worn out.
Clean the rollers with a rubber cleaner or alcohol, clean the paper path with alcohol, check for sticky areas, adhesives from post its or signature flags.
Clean the scan glass with a good glass cleaner.
Blow out sensors with compressed air (Computer Duster), if sensors have an actuator arm, ensure the arm is in place and moves freely.
Give this a try.
Hope it is of some help.
Ed
2helpful
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Paper jambs in the feed. The right side seems to pull down first then just jambs up.
Solution: Remove foreign objects from Rear Tray MP210
Remove foreign objects from Rear Tray When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once. Follow these instructions to remove foreign objects from the Rear Tray.
  1. Power the printer off.
  2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. (If there is any foreign material, remove it by hand or with tweezers.)
Open the scanning unit (printer cover) and confirm that there is not any foreign material in the printer. (If there is any foreign material, remove it by hand or with tweezers.)
Note : After confirming that the scanning unit support < 1 > is fixed into position, release your hands.
Caution: To prevent injury or damaging the unit, avoid touching the inner parts.
  1. Close the scanning unit (printer cover).
    Caution: Be careful not to pinch fingers when closing the cover.
  2. Power the printer on and confirm that the printer operates normally.
    Note: If you cannot remove the foreign material in the above procedure, the printer may require servicing.
And
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
  1. Remove all sheets of paper from the rear tray, then click 'OK'.
  2. Confirm the following message, and click 'OK'.
  1. Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
6efb7a7.jpg After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
Note: The following message is displayed when the paper is fed and ejected.
  1. Click 'OK'.
Cyber Kaka
6answers
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
  8. Click 'OK'.
Paper feed problem.
ATN master 3202 clean paper feed rollers with a micrfiber cloth moistened with rubbing alcohol will be rollers that pull paper probably just need wiping off after a lot of use these rollers build up paper dust that causes traction problems
2answers
Dell 924 paper feed
you need to clean paper feed rollers with isopropanol alcohol on a microfiber towel or get a sheet of cardstock to print on as it prints it will force out any foriegn material
To correct paper feed function make sure feed sensor lever isnt broken
old marine
old marine
ZJ Limited
ZJ Limited
