Smart Drive 703
SOURCE: Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
SOURCE: Smart Drive 703-strange noise during wash cycle
hi there these washing machines don't have any pelts or pulley's. Washer will need new seals and bearings witch is a big job, you wont be able to do it your self as you need special tools to put the bearings back in :)
SOURCE: my smart drive is not reaching full spin speed on spin cycle
You are right with your last comment. Laying the machine on its back is a no no. It allows the residue water in the bowl to possibly travel up the small plastic tube and enter into the water level sensor on the main (computer) control unit. It only takes a very small amount of water and it upsets the sensor so that the machine may not go through its cycle correctly. The water (depending on model) is extremely difficult or impossible to get out.
This may cause the machine to think that the bowl is not completely drained and so it will not go into full speed spin. Other problems may occur as well.
Bear in mind also that that a number of machine models do not go to full speed spin on a water temperature setting of warm or higher. When checking for high speed spin put your water temperature control down to cold / warm or cold.
Check also that your machine is sitting level ( the bowl is sitting centre in relation to the top shroud. If the bowl is leaning toward the rear of the machine when you look down into it, the ability to spin may be affected. There is a lever behind the bowl which activates a switch if the bowl comes in contact with it (when the wash load is out of balance) to stop the spin. The switch can also be activated when the machine is not level.
If your problem persists you may have to get a replacement main contol unit. If you are a little savey at technical things you may be able to get a discarded control unit from your local tip or recycler and recover the water level sensor for a change over. This may involve soldering though as well as precautions concerning stored electricity in the control unit capacitors and precautions about static electricity from your body or solder iron destroying other electronic components on the main control unit.
Hope this helps.
SOURCE: water filling issue
It sounds like you have a faulty Out of Balance Micro switch(the machine now thinks it's always out of balance) you'll find this under the motor controller module (main computer module) in the top of the machine on the righthand side. Anymore questions feel free to ask. cheers
