Its illegal for
anyone to provide serial keys for programs that have retail value set on them
If you are trying to
recover a key of an already installed program on your computer there are
freeware keyfinders on the internet
http://download.cnet.com/%7Bvalue=http://www.download.com/magical-jelly-bean-keyfinder/3000-18487_4-10079600.html The Magical Jelly
Bean Keyfinder is a freeware utility that retrieves your Product Key (cd key)
used to install windows from your registry.
It has
the options to copy the key to clipboard, save it to a text file, or print it
for safekeeping.
SP3 is the third and final service
pack released for Microsoft Windows XP, and it eliminates many of the security
holes that previously affected XP.
While Microsoft recommends that
users download SP3 using Windows Update, some users are unable to do so.
However, it's easy to create a
Windows XP SP3 installation CD; it requires only that you download the pack
from the website and burn it to a CD-R/DVD-R using an ISO burner program.
Download the SP3 installation ISO by visiting
the first link listed in the "Resources" section of this article. Save it to
your Desktop.
Download ImgBurn and save it to your
Desktop.
Double-click the installation
executable for ImgBurn and click "Next."
Follow the remaining onscreen
prompts and click "Finish" to complete installation of ImgBurn.
Insert a blank CD-R/DVD-R into your
DVD drive.
Open ImgBurn by going to
"Start," "Programs" and "ImgBurn."
Click "File," then "Browse
for a source file."
Navigate to your Desktop and select
the SP3 ISO file.
Click "Open."
Click the blue "ISO to CD" button
located on the bottom left of ImgBurn.
The program will begin creating the
Windows XP SP3 installation CD.
This process may take anywhere from
10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is
being burned.
Click "OK" once the CD-R/DVD-R has
finished burning.
You've successfully created a
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
XP PRO SP3 ISO
Download the iso also download the imageburn
http://www.imgburn.com/
http://windows-xp-pro-startup-disk.soft32.com/
The process "winlogon.exe"
runs in the background.
Winlogon is a part of the Windows Login subsystem, and is necessary for user
authorization and Windows activation checks.
http://www.neuber.com/taskmanager/proces...
Note: The winlogon.exe file is located in the folder C:\Windows\System32. In
other cases, winlogon.exe is a virus, spyware, trojan or worm! Check this with
Security Task Manager."
Microsoft designed Windows so many
small applications perform their tasks without a user knowing about it.
Normally, this will run smoothly and
without flaw, but every once in a while, an issue can come up.
Winlogon.exe is an application that
runs on start-up, and its primary function is to monitor the use of other
applications.
Winlogon.exe typically only runs for
about a minute or two when Windows first boots up, so if for some reason it is
still running five or 10 minutes later, it could be infected.
Spyware and other malware would
infect this application because it can manipulate other programs in Windows,
causing problems.
If this is the case, the file might
need to be removed.
if you want to remove this from
Open "My Computer" and
select the "C:" drive.
Double click the "Windows"
folder, then select "System 32." Navigate through the System 32
folder until you find "Winlogon.exe."
Click the "Winlogon.exe"
file and hit "Delete."
Select "Yes" when asked if you're sure
you want to remove the program.
