Weither on low, medium, or high selection for water level......machine will not recognize and fills continuously....Any ideas would be greatly appreciated, thank you
same unit same washer 3 to 5 years old. Washer over filled and flooded the house.same unit same washer 3 to 5 years old. Washer over filled and flooded the house.
Machine does not stop filling. As a result it overflows unless water is turned off at supply.Machine does not stop filling. As a result it overflows unless water is turned off at supply.
You can't post conmments that contain an email address.
Either your waterlevel switch is bad or the hose from the tub to the switch is leaking air. more info would help..ie do you have to turn the water off at the wall for the water to stop rising or do you just have to push the timer knob in?? let me know, i can definitely help to diagnose!!
You have a faulty fill valve. Return/ replace you washer if under warranty. If not then you will have to replace your fill control valve. That valve is where the knob for the fill level is.
Hi Robbie just read your posting.Now just a couple of questions.Does the machine keep filling and flood?Can you manually select the amount of water for the wash --eg-- low, medium,or high?Or does the machine drain and fill at the same time?Please reply with additional information on the questions and I am sure I can rectify this fault for you.
r u using auto fill mode?if u r then try selecting high medium or low. check water pressure coming out of inlet hose, could b faulty valve not letting enough pressure thru.please reply if u need more help
Good day,
If it keeps filling, and can't then it sounds as if you have the drain hose positioned too low.
It must reach a point higher than the highest level the water will ever reach.
Hi, If you turn the water source valve on and water starts filling the machine even tho the machine is off, change the inlet valve. If you have to start the machine so water will fill but, the water does not shut off at the desired level, there is a problem with the water level switch. I hope this helps you. Please let me know if I can assist you further.
raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
