Trying to use a RCA Universal Remote
If you have the code book just hold the device you want to set up
like tv, vcdr, etc. and the power button at the same time. The power botton will stay lit. Put in your 5 digit code...hold it till the tv,vcr turns
off. Turn it back on and try the rest of the functions. If it dose not work
on certain function just hold down that key till that function works. Hope this helps.
SOURCE: Lost TV remote for Coby Flat Panel TV, 17inch
Universal remotes are not compatible with any Coby TV. You can get a remote directly from Coby:
Send:
$6 Money Order - 'Made out to Coby Electronics'
note with your name, address, phone#, model# and what part you need
Send to:
Coby Electronics
Att: Customer Service
56-65 Rust St
Maspeth, NY 11378
SOURCE: Program a universal remote for the Dynex 32" 720p Flat Panel
Try using the codes listed for Orion products. Worked for me.
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
