PC device connects through same network fine. iPad doesn't see printer when I do a search.
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
SOURCE: linksys SPA2102 interfearing with winmx/360 sharepro, frequently resetting connection
If your planning to connect the phone adapter behind a router make sure that the following ports are open/forwarded on the router; UDP ports 5060-5061, UDP ports 16384-32767 take note that 5060 and 5051 one are SIP ports and must be assigned to the IP address of that was assigned to by the router to the adapter or the IP that was manually configured on it.
I found a link that could help you check the setting on your linksys phone adapter
http://www.voipvoip.com/linksys-pap2/
Hope this will help you solve your VOiP problem...
Regards,
SOURCE: Using Linksys WRT54G as router connected to ActionTec with FIOS
You must keep everything on the same subnet. Only allow the router to be DHCP and keep everything on 192.168.1.x subnet. You are going to have alot of problems talking across subnets
SOURCE: can't install linksys wrt54g2 router with arris tm602g modem
I've tried network magic and everything thing else and I still can't get it to work.
