SOURCE: Installing a second sata hdd
have you check the jumper setting in the drive and the connect it to slot 2 not the slot no 1
SOURCE: Hello
i want to register a complaint for hard disk drive
Model No. : HDS721616PLA380
cAPACITY ; 160 GB
ADDRESS ; 104, 1/50, GANGA APPARTMENT, LALITA PARK, LAXMI NAGAR, DELHI-110092.
PH. 9899970450, 9868270450, 99999073373
ASRAR ALAM AZAD (PROPRIETOR)
SAURAV CHATTERJEE (EXECUTIVE)
Generally there is a small screw, (Or two of them), that go through a thin metal tab, affixed to the harddrive. They usually have a strip of thin cloth, that you pull on, to ease the harddrive out, after the screw is removed. Sometimes it's hard to see.
I have to give you this information in a generic form, because laptops differ in the way they keep the harddrive in. I better go ahead, and tell you, that this specific info may not be available, for your particular laptop. However, you may want to come back, and post the laptop manufacturer name, and model number, in case it is. (I've worked on many, and have a lot of information available, but am being straight up front with you, that I do not have info available for every laptop out there. Just trying to help, is all)
SOURCE: sata HDD very slow
Dear friend you need a sata board to get maximum speed of sata driver connect it directly to motherboard sata jack converter does not give full sata speed
SOURCE: When installed the HDD spins
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive Test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
