SOURCE: won't move pronto m51
Three lights flashing on your chair indicate a left motor fault. Make sure that all of the connections inside the shroud are tight by physically testing them. If all of the connections are good, and the fuses are good, then it's time for a trip to an authorized repair facility. Here is a link to the M51 owners manual if you haven't one. Page 24 has the fault code guide.
http://www.invacare.com/doc_files/1125085.pdf
The controller monitors all of the functions on the chair, brakes, motors, joystick, charger etc. The three flash fault indicates an "open" circuit. Open, like a switch or blown fuse is open, or a wire is cut or burned in half, or a connector is unconnected, or partially connected. The latter is what you are hoping for. Wires burned in half is the usual cause for a motor fault, and with powerchairs, is usually the result of the chair getting stuck in or against something it can't get out of and the operator over-amping the motors. Motors do, just go bad sometimes, for no reason. Very rarerly, however.
You can also check the brushes on the motor too. There's two quarter-sized black plastic screw-plugs on the ends of the motor opposite each other. Unscrew them and examine the brushes. The springy coils should be springy. Overheating can cause them to be brittle, or even burned in two. Check the lench of the brush, the dark rectangular cube at the end of the springs. It should be curved and polished at the end, and a little over a half-inch long. If it is near a 1/4 inch, it needs replaced, or if there is any evidence of overheating, replace. Good luck.
SOURCE: battery won't charge
Most likely you need new batteries. On the M51 powerchair the batteries are located in the center under the seat. Step 1 - remove the seat by pulling up on the swivel handle while lifting straight up, the seat weighs about 50 lbs. After removing the seat remove the center plastic cover by liting it off.
If you have an older model M51 the batteries will each have their own cover - to replace the batteries you will see several connectors that must be unplugged. The front and rear batteries each have different connectors so keep them separate. Lift out the batteries and follow the wiring for each replace the batteries. You will need 2 U1 batteries, available at sears or your local maedical equipment supply store ( Interstate has them too) Simply reverse the removal procedure to replace the batteries making sure you follow all the connections. - good luck
Tom
SOURCE: only 1 battery charges
The lights are working, the batteries aren't. Red indicates power to the charger, and it should be on all the time. Green indicates a full charge, usually. If one or both of the batteries are totally dead, then the charger can't "see" them, and you will get a green light, but you will have dead batteries.
All power chairs use sealed, deep-cycle batteries. Deep cycle batteries, are designed for slow amperage dischare over a long time period, unlike a car battery that throws out a lot of amperage for turning the motor over. That's called "cold-cranking amps", and you can load-test a car battery to see if it will throw out a ton of amps for long enough to start a car. There is NO load tester made, or possible for a deep-cycle battery. A load test requires a 24-hour time period, and a complicated formula.
So, your course is to get some fresh, gel-sealed-batteries. You will need type U-1. Specify, gel-sealed-batteries when you go to the battery shop. A fresh set should get the chair up to about 12-16 mile range, which would be about 3-4 hours running constantly at high speed. Good luck.
SOURCE: My Pronto M51 chair does not seem to be holding a
Have the batteries load tested. It sounds like the batteries need to be replaced.
SOURCE: control box on pronto m51 wheelchair don;t work
When you say "control box" I assume that you mean the joystick. If there is no power to the joystick be sure that the batteries are fully charged and be sure that they do not need to be replaced, also be sure that the cables were not put on wrong. If all that checks out then be sure that all the cables are tight.
If all these do not solve the problem then you need to have the joystick tested.
