When I turn on my lap top it reads this message Operating System not found
SOURCE: operating system not found
this is the problem that is arised when u try to install 2 OS at one time. for example if u install XP and winn2000 together this problem is arised. The thing is that u have install new operating system with the help of cd/
SOURCE: Operating system not found, hard disk not found message showing in IBMT20
Your hard drive is most likely bad or the ribbon cable is not connected.
Yep, your operating system has crashed, not your hard drive, but the windows on the hard drive..
simply boot from your windows cd / dvd and choose upgrade as the instillation type or leave current file systems intact so as you install windows over again, you dont loose your previous data..
the laptop is unable to read operating sistem from disk - you have to try to insert recovery disk after changing in the bios (you can read on laptop manual how come in bios for changing to first boot is hard disk to first boot is cdrom or dvd or cd ) after that you can try to recovery the operating sistem - it may be not so easy delfo
You're on the right track. For whatever reason it failed an operating system repair is in order. You need to use the same operating system XP Home / Pro / MCE as was originally on the unit. Mayve a relative of friend. Don't use restore disks. These will erase everything on the drive.
