Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Cold wash would like to know if i can just use the cold water full for washing machine it is a whirlpool american collection ultimate care 11
  • magbefunny Dec 29, 2008
    sorry i did not put the number in before but here it is now hopefully this will help it is the model number 3RLSQ8000JQ4 and here is the serial number CS3501658 .. THANK YOU
    Scholar:
  • 86 Answers
Hi if this intended to be used in a commercial environment then it will need to be hot and cold water supplied as commercial machines do not have heaters! I can tell you for sure if you give me the exact model number..
Posted on Dec 28, 2008
Anonymous
SOURCE:
I load washer it starts the wash cycle it goes through wash cycle fine drains water but does not collect water for rinse cycle it just idles. So I turn knob to spin and it spins until done.
If it doesn't fill for the rinse, I would say that the cold inlet valve has failed. Check that the cold tap is turned on and check when the machine fills for the wash cycle and see if it is taking hot or cold water. You will probably find that it is filling only with hot water. A local spares store should have the valve you need.
Sep 17, 2015 | Whirlpool Ultimate Care II LSQ9564J Top...
Does not take water ,hot or cold
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jun 16, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Standard washing machine hoses dont seem to fit my Whirlpool Ultimate Care II washer? Do I need an adaptor of some sort....
The Whirlpool Ultimate Care II is an American top loading washing machine and requires different hoses available from Whirlpool.
May 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Hot water on cold washes
To solve this problem simply reverse the water hoses from the way that they are set up currently. Then do a test again to make sure that when you select HOT you are getting HOT.
Nov 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
How do i clean the Whirlpool Gold american collection top loading washing machine? I can see no filter to remove and the inside of the tub is getting dirty. The holes inside the tub at the top seem to be...
Dumped even more HOT HOT HOT water while poking around inside dispenser. Softener dispenser suddenly became unclogged and water began running out of the opening showing me that the dispenser was indeed clogged with softener buildup.
Sep 20, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine not heating water
yes it will work but unless you have hot water going into the machine there will never be hot water there but you can just use it with cold water will not hurt anything just no hot water
Mar 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool american colleretion
Hi, Yes you can run this appliance on just cold water using a Y piece... Just connect the 2 hoses together on the Y piece and connect to the cold water!!.
Good luck and happy washing.......
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine
If it is a hot and cold fill m/c, then you can just use it from cold water.
You would need to fit what is called a Y piece connector , this supplys water to both hot and cold valves regardless of what prog you select..
You connect the cold supply to the straight leg of the connector, and the hot and cold to the other 2 connections.
Plz rate this solution.
Thanks.
Dec 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
109 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
