Recently i gave my 1650 phone for charger connector service, when i got it back, my tata docomo sim doesnt work on it.. it says sim card registration failed ... none of the tata sims work but all other sim cards like idea vodafone airtel work on it .. now they advice to flash the phone.. but if i do that ill lose all my imp messages tat ive been preservin since a long time.. now no other option .. evn if im flashin i want to save all my messages.. if anybody has a solution, please help.. means a lot !! my email: [email protected] phone +919901587950
SOURCE: SIM card registration failed
You might have filled up the memory to the brim and the phone doesn't have enough to switch on.
Try reformat to original settings. anything you stored on the phone will be lost.
How to reformat your phone, first turn it OFF. Press * 3 send at the same time and keep them pressed while you turn the phone on.
Give it time to work.
Remember, do not let go the 3 keys until you see the formatting screen.
After a few minutes when the process is over, your Nokia N70 will be back to the original delivered system.
SOURCE: the phone keeps displaying sim card registration failed on phone
you have to enter some code after u enter the sim
check out this link
http://www.gsmliberty.net/shop/nokia_unlock.php
i dont assure you but i think it will help you.
thanks.
SOURCE: my nokia 5300 handset not working in all sim card
this phone might have been made only to detect the airtel sim cards as the phone in question might have been made only for the air tel company
in collaboration with nokia .
so there might be no code for it to allow all the sim cards .
imagine it like the cdma phone distributed by reliance communications
SOURCE: nokia e65 will not accept any sim card after i unlocked the phone
I would try the unlock again, it sounds like the unlock was unsuccessful otherwise it would have allowed you to use the other sim cards.
SOURCE: theres this message on my phone that keeps popping
its ur sim which got damaged no issue in handset
Run pc suit and add ur mobile device
Go to internet connector and add a network connection
settings
Set name; TATA DOCOMO INTERNET
Country; india
Isp provider; TATA
Apn; TATA.DOCOMO.INTERNET
USERNAME; BLANK
PASSWORD; BLANK
OK
THEN CONNECT WITH IT . mobile gets automatically disconnect
and then connected with a long msg error.
Then close the pc suit
Now open control
panel
Go to network connection in xp
Go to properties of TATA DOCOMO INTERNET
CHANGE the phone number from #777 to *99***1#
Then ok and connect.
