I am Unable to connect my Aduio cables from the xbox 360 to my TV
I am Having troubles connecting my Xbox 360 to My Technika 22@ HD Digital LCD TV/DVD (Model LCD22-208). The Audio cables don't seem to have anywhere to connect.
there is the green,blue and red pins and sockets but there is now where to plug the old red and white audio pins on a tecknika pro lcd 22-308
AnonymousMar 23, 2009
what do you mean when you say select input of scart on tv? what do you mean when you say select input of scart on tv?
AnonymousApr 04, 2009
This may fix the problem but quality is poor due it not being hd This may fix the problem but quality is poor due it not being hd
AnonymousApr 30, 2009
yeah, you either need to get a hd cable or use an adaptor for red and white cablesyeah, you either need to get a hd cable or use an adaptor for red and white cables
You can't post conmments that contain an email address.
Re: I am Unable to connect my Aduio cables from the xbox...
1) Connect the red, white & yellow audio leads in to the 360 scart adapter and then plug this in to the scart socket on the tv
2) change the xbox 360 selector at the back of the console from HD to TV
2) Select the input of scart on the tv
I myself have a 46" RCA LCD flat screen tv, which I have my xbox 360 connected via HDMI cable. If your tv has audio out "rca plugs", which im sure being a newer 3d HD tv, connect the supplied cable to the audio out (red, white) plugs, and then connect your headphones to that jack!
your HD settings may be too high, go to "display settings and change them, if your not on an HD tv, change the output to "TV" on the AV cord where it connects to your xbox, if you Are on an HD tv make sure the output is set to "HDTV" on the AV cord where it connects to your xbox, there is a little switch on the side that slides left to right
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables).
-Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
My TV has a Output port, It is only output for sound, IF you TV has this, then you need to use those, But i dono if it would have them, If it dosent the you will not be able to use the surround for everything without Plugging it in as you use it,
I have it and it works great!
For all TVs, the TV have to be on fixed settings on standard, dot-by-dot mapping, noise reduction off. The camera's exposure the same for both side-by-side shots.
Just set it on standard and it should work...
