Nikon D40x Digital Camera Logo
Posted on Sep 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
D40x sharp spots on long exposure pics - Nikon D40x Digital Camera
Bart Pulverman
Level 2:
Guru:
  • Nikon Expert 362 Answers
  • Posted on Dec 17, 2014
Bart Pulverman
Nikon Expert
Level 2:
Guru:
Answers
362
Questions
0
Helped
83779
Points
625
Hi jchp_2001, I want to help you with your question, but without more information from you, I can only guess what you mean?
What do you mean by "sharp spots"? I will assume that you are talking about speckles of white or colors in the deep shadow areas of your pictures or in black areas of night time exposures. What you are seeing is electrical noise generated by your camera's sensor and amplified by other electronic circuitry in your camera. Newer and more advanced cameras have higher signal-to-noise (S/N) ratio circuitry that reduces, but does not entirely eliminate the problem. The S/N ratio is a measure of how much stronger the picture information is than the electrical noise (analogous to to the static you hear on a week AM radio station). The higher this ratio, the fewer artaffects, such as spots, will appear in your pictures. There are a couple of ways to lessen this problem. You could use a shorter exposure time, lower the ISO setting on your camera (of course that would increase the required exposure time and my nullify the benefit), or illuminate the shadow areas with supplemental lighting. The other way is to buy a newer camera that has a higher S/N ratio. One of the main goals in new sensor and camera design is to raise the S/N ratio. Trading in your D40x on a newer model DX (24x16mm sensor) format camera will help. The reason that professionals more advanced photographers spend thousands of dollars on full frame (36x24mm sensor [the same size as a 35mm film slide]) digital cameras such as the D600, D610, D800 or D810 is because the larger sensors have an inherently higher signal to noise ratio. That is in part why your D40x gives you better quality pictures than a Coolpix camera for example, which has a smaller sensor.
2 Related Answers
Anonymous
  • 2985 Answers
  • Posted on Jan 31, 2009
SOURCE: Nikon D40x Metering Problem
I assume this is no longer under warranty.
This more likely to be a case of not pointing the camera correctly when pressing the release if for example you press the release firmly and dip the camera down in so doing it will register a shadow the camera moves up on exposure and you get a burned image.
Try various experiments in the mode see what happens.
As regards a repair it is likely the cost would be as much as or more then a new replacement
Contact the Nikon customer support
michael galang
  • 138 Answers
  • Posted on Feb 07, 2009
the meter should turn on as soon as you half press the shutter. otherwise remove the lens and try cleaning the electrical contacts on the lens and on the camera body.use q-tips dipped in very light spirits of alcohol, make sure you dont leave any debris around the area. caution with the camera's sensor.
Dark exposure
Check your ISO setting...should be between 100 to 400 for normal pictures.Did you change your exposure compensation setting to something other than "0"? Is the aperture ring on the lens set to the "A" position?
1helpful
Can D40X do double exposure on a single frame
The D40x does not have this facility.
All you can do is to combine two exposures in your processing software; it's best controlled by combining two or more RAW images.
My Nikon D40x took white out pics on the beach
You most likely were shooting in a mode that caused your exposure to over-expose your image. Try "Auto" for starters. Once you are comfortable, learn to set "A" or "S" to control your shots as "you" want them. be sure to know how the camera is metering the shots too. All of this is explained in the manual.
2helpful
2answers
Cannot take pictures thru lcd screen on d40x DSLR
The D40x is not capable of Liveview - i.e. looking at the LCD to take a picture. You are mistaken.
If you want Liveview, you need to buy the D3 or D300 cameras. The D40x is an entry-level camera.
2answers
All white pic is shown on LCD when used in Manual Mode with delayed shutter timer
You are massively overexposing the picture. Manual mode means you have to set the exposure manually. You need to adjust the settings so that the light meter reads somewhere around the zero mark.
M mode is most useful for flash photography where you want a certain level of ambient illumination in the picture as well.
If you want some control over the camera but don't want to worry about exposure too much, use A and S modes. The manual will explain all of these modes.
D40x Camera with mirror lens = black pictures
Usually tele lenses need longer exposure,and mirror lenses need more than normal lenses.Try with 1sec, half sec,( 2 in the speed dial, not 2" ) or quarter sec (4 in the speed dial) exposures.
One more thing, you need good sturdy stands to hold cameras.
2helpful
3answers
A faint spot in all of my photos!!!
For me the issue was flecks of dust on the CCD. Complete fix for d40x effected as follows:
(You will need a 'rocketblower' or similar air cleaning device)
Take the lens off. Set camera to Manual setting and spin around to 'bulb' setting, press the button to shoot but hold it down. You will see the CCD exposed inside the hole where the lens usually attaches. Then taking care not to touch the CCD with the rocket blower give it a few blasts of air onto the ccd. (Possibly before you do this hold the camera at an angle to the light and you might see the dust flecks I had on the CCD.) Then replace let the button go and replace the lens. Voila.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
