You can reset the device back to factory setting by holding the power button for 15-30 seconds. CAUTION it will clear away your address book and any custom set ups you have done.
You also might contact your cell phone provider
You can reset the device back to factory setting by holding the power button for 15-30 seconds. CAUTION it will clear away your address book and any custom set ups you have done. You also might contact your cell phone provider
I think you need to try with an other sim card, probably it could be the simcard problem.If you find it is a device problem then try to update the device.
You can try to do factory reset on your tablet so that your tablet would get unlock.
1.Press the power-key and volume-down key at the same time until the phone get into the recovery mode. 2.Press home key to get into next interface. 3.There will be four choices: reboot system now;apply update from external storage ;wipe data/factory reset;wipe cache partition. 4.Use "Vol+" and "Vol-" to move the cursor up and down. 5.press power key to select wipe data/factory reset.
Adjust the window size to the size you want to capture. Hit the Alt key and the Prt Sc (Alt+Print Screen) at the same time. Open the application you want the screenshot in and use the paste command (Ctrl+V).
