SOURCE: Maytag stacked washer/dryer model no. LSE7806ACE;
Hi First
make sure that nothing is blocking the drain pump assembly located inside the
bottom of the unit, after this test the door switch assembly, if the door switch is also fine then the control board should be
replaced. Hope this helps...please post back for further assistance.
Daniel
SOURCE: My stacked Maytag washer/dryer model
what you can do without harm is remove the washer front panel and tug on the top and it should pull out...you can also raise the front washer legs up into the machine and that too will make it easier to pull out...be sure when replacing the lid switch asm to replace the fuse which is on the rear of the left side washer cabinet panel once front panel is removed
