You can get the Unlock code from the site
Mobile-unlocker.com/samsung-e1081t/rs2wp9/ for SAMSUNG E1081T model phone and unlock it easily.
Hi ,
insert a non accepted sim in your phone ..turn it on then type *2767*3855 # ,wait until it reboot ...you can used now the sim card you want because it is now in unlock mode...if you turn off the phone at back in lock mode ,just repeat the procedure ...
SOURCE: I have forget my samsung mobile code's model
Try the under codes to format your phone which will let the codes get gone: *2767*3855# *2767*3855# rate my answer
SOURCE: hi, i need a puk
Hi PUK code is called as PERSONNAL UNBLOCKING KEY. Your phone will ask for PUK code when you entered the PIN
code wrongly several times depending upon the mobile make. The mobile asks for
PUK code so that unauthorized persons do not use your mobile for wrong cause. To get PUK code please contact your service provider
through phone or go directly to their office. They will provide you the PUK
code for your mobile. The PUK code is unique for each mobile phone model.so
that you can open your phone. When you planning to call your service provider
you cannot use your mobile as it is fully locked. Please use some other mobile
with same network to call your service provider. This PUK code prevents thieves from being able to make use
of stolen handsets, that is why it can only be given by the service provider
only. While you get the PUK code ,the service provider
customer care officer will ask for your personal details to check whether the
mobile belongs to you only. If they are satisfied with your answers they will
provide with the PUK code DONOT enter the PUK code several times wrongly,It will
block your sim card permanently. This PUK code is FREE. You no need to pay any money to
get the PUK code Thank You.
SOURCE: My samsung GT c5510 phone
Pullout your battery and look closer at the back.. should be there in plain text. That's on the phone not on the battery.
Testimonial: "thank you very much! found it!"
