Got my dish network remote to now turn on my tv but cant change the input to av 1 so that the dish network will work
SOURCE: AV 1, AV 2, AV 3, but no TV
that's thing happening you tv epprom ic. replace back same # epprom . good luck!
SOURCE: how can i change my tv from tv to vid1 and 2 without a remote?
I looked at the manual and it seems like there is no way to do it thru the menu button.
You can download the manual here.
http://www.funai-corp.com/6pdf/om/IWT3206.pdf
SOURCE: need remote codes
You may be able to get help here. This is a link for the owners manual in PDF.
Hope this helps!
http://dukeelectronic.com/Manual/IWT3206.pdf
SOURCE: av mode no remote
Just off the top of my head I think the code was 720... I havent installed DishNetwork dishes in a while though.. I will double check to get you the right code.
SOURCE: How do you change the chanel to AV without remote, dont give the option on the tv buttons
check the website for the remote you have bought and enter the codes for newer models of your make of tv keep trying 1 of them should work but might not give you all functions like teletext
no av input but has av outlets cant figure out how to se it to av, no remote either
