There could be a variety of reasons why your OPPO BDP-83 is not playing discs when you turn it on. Here are a few things you can try to troubleshoot the issue:
- Check the disc: Make sure that the disc you are trying to play is clean and undamaged. If the disc is dirty or scratched, it may not play properly.
- Check the disc format: The OPPO BDP-83 may not be able to play certain disc formats. Consult your owner's manual or the manufacturer's website to see which formats are supported.
- Check the connections: Make sure that all of the connections between the OPPO BDP-83 and your TV or home theater system are secure.
- Check the firmware: If you have not already done so, try updating the firmware on your OPPO BDP-83. This can sometimes fix issues with disc playback.
If you are still experiencing issues with your OPPO BDP-83 after trying these steps, you may want to contact the manufacturer or a qualified technician for further assistance. They may be able to diagnose the issue more accurately and suggest the appropriate repair.
BDP-83 When turning my BDP-83 on to use the word Hello show on the display and goes not play the move. when I trie to turn the system off i have to hold the power botton in for about 30 sec. before it turns off.
