do you have a model numberdo you have a model number
AnonymousMar 16, 2014
Won't turn onWon't turn on
AnonymousMar 18, 2014
The machine won't wash and only displayed the red flashing buttonThe machine won't wash and only displayed the red flashing button
AnonymousMar 24, 2014
Where in the control panel is the control fuseWhere in the control panel is the control fuse
AnonymousMar 25, 2014
when lid down machine did not start but put weight on it and it started. Now machine does not start at all with weight on lid. Water temperature lights all flash insteadwhen lid down machine did not start but put weight on it and it started. Now machine does not start at all with weight on lid. Water temperature lights all flash instead
AnonymousMar 29, 2014
top loader lid locked no power to machinetop loader lid locked no power to machine
AnonymousMar 30, 2014
have tried to remove, unsucessful, so how do we remove the outer top of machine, as the body is all in one???have tried to remove, unsucessful, so how do we remove the outer top of machine, as the body is all in one???
You can't post conmments that contain an email address.
Hi just read your posting.After the 1st wash cycle the machine drains the water,Is the machine continuous draining?Or does the machine stop the draining and sit there silently?Please reply with additional information and I am sure I can help you.I have worked on this machine alot so if you reply back we can rectify the problem.Looking forward to your reply.
I have a error code Ld come up on my Simpson eziset 5.5 kg top loader washing machine what does that mean ? Also is it possible to replace a sensor battery for that. Model and what size battery replacement do I need to ask for
If you can use a lollipop stick to operate the lid switch while you leave the lid open, you will be able to observe if the agitator is going smoothly back and forth EVENLY or not. If it is tending to turn just one way....this will tangle the clothing like mad! If this is the problem it could be the switching module or capacitor that needs replacing.
5 beeps with the 3 temp lights flashing means lids not closed. or lid switch not working
i just fixed this problem. the magnet in the lid had come loose. I undid the two screws on the side of the lid put the magnet back where it should sit then i poured candle wax over it to hold it in place and working fine now.
model 365550
serial 425-70946
app s91-5.5kg
electrolux home products pty ltd.
Won't turn on
