SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
SOURCE: problem with our Brother mfc-7840w toner all over the page
please check the life of your drum, probably that are the problem.
SOURCE: How do you reset a Brother MFC-7840W printer to
Menu * 2864 (within 2 sec.), 0,1, when 'maintenance' appears, press 0,9 to exit.
SOURCE: I changed my toner on my brother MFC-7840W
you cant!your lucky its working,most brother printers will not do anything with an aftermarket cartridge-just ignore it and use your commen sense to decide when the inks going
SOURCE: MFC-7840W Printer: need tp set the wireless setting, lost the instruc...
To setup your Brother MFC-7840W on a wireless network do the following:
Press Menu.
Scroll down to #5 LAN and hit OK
In the LAN submenu, scroll down to 2. WLAN and hit OK.
In the WLAN submenu select 2. Setup Wizard.
(The printer will search for the SSID of your network. If you are presented with multiple networks, select yours and hit OK.)
Depending whether you have setup a network key on your wireless network, you will have to choose the type of connection. Your options will be Open System, Shared key, and WPA/WPA2-PSK.
If you have a Shared Key or WPA/WPA2-PSK network, then you willhave to enter the key to connect. Open Key does not use a key to connect.
So for instance, if you selected WPA2-PSK you will then be asked to enter your passphrase key to connect to your wireless network.
