The above shown boxes help you unlock or read codes from your nokia mobile ( any model) without effecting the phone data........either purchase them ( any one) or get the job done by a service person
This is from the Nokia 2730c manual: "Access codes The security code helps to protect your phone against unauthorised use. The preset code is 12345. You can create and change the code, and set the phone to request the code. Keep the code secret and in a safe place separate from your phone. If you forget the code and your phone is locked, your phone will require service and additional charges may apply. For more information, contact a Nokia Care point or your phone dealer. The PIN code supplied with the SIM card protects the card against unauthorised use. The PIN2 code supplied with some SIM cards is required to access certain services. If you enter the PIN or PIN2 code incorrectly three times in succession, you are asked for the PUK or PUK2 code. If you do not have them, contact your service provider. The module PIN is required to access the information in the security module of your SIM card. The signing PIN may be required for the digital signature. The barring password is required when using the call barring service. To set how your phone uses the access codes and security settings, select Menu > Settings > Security."
Google translation:
Ini dariNokia2730cmanual: "Kode akses Kode pengamanmembantu melindungi teleponAnda dari penggunaanyang tidak sah.Kode awaladalah 12345.Anda dapat membuat danmengubah kode tersebutdanmengatur telepon agarmeminta kode.Jaga kerahasiaankode dandi tempat yang amanterpisahdari telepon Anda.Jika Anda lupakode dan ponselterkunci,ponselharus diperbaiki danmungkin dikenakan biaya tambahan.Untuk informasilebih lanjut, hubungipusat NokiaCare ataudealer ponsel Anda. Kode PINdiberikan bersama kartuSIMmelindungi kartudari penyalahgunaan. KodePIN2 yang diberikan bersamabeberapa kartuSIM diperlukan untukmengakses layanan tertentu.Jika Anda memasukkanPIN atauPIN2 sebanyak tigakali berturut-turut, Anda akan dimintauntukPUK atauPUK2.Jika Anda tidakmemilikinya, hubungipenyedia layanan Anda. PINmodul diperlukanuntuk mengaksesinformasi dalam modulkeamanan kartuSIM Anda.PIN tanda tanganmungkin diperlukan untuktanda tangan digital.Sandi pembatasandiperlukan bilamenggunakanlayananpembatasan panggilan. Untuk menetapkancara ponsel menggunakankode akses danpengaturan keamanan,pilih Menu > Pengaturan > Pengamanan."
kamu masuk ke pengaturan>pengamanan>ganti kode pin ponsel, lalu masukan kode : 4751577245 , lalu tekan ok, setelah itu kamu masukan kode hp yang baru sesuai yang kamu inginkan
jangan lupa! Kasih nilai jika solusi saya membantu anda
Nokia 2626Signal No Network repairing solution.Nokia 2626Signal No Network Mobile Repair diagram pictures Service Tips and Tricks.Make Jumpers as shown in diagram or replace the shown components . How to short Nokia 2626 PA.jumper Pa nokia 2626. here is a diagram that is showing how to jumper and short P.A of nokia 2626. it is used to check that mobile is getting signals or not. if signals are to low with jumper change the P.A
