See this causes and fix it. God bless you
1. No power to the washer
Make sure there's power getting to the washer. Check for a
tripped circuit breaker or a blown fuse. Check the wall socket for
power. Sometimes the power cord disconnects at the washer, if this is
the case, the wiring must be repaired or replaced.
2. Lid switch
The washing machine may not function if the lid switch is defective.
The switch is usually located near the door. Replace if found
defective.
SOURCE: kenmore HE2T front loading automatic
"F22" is a door latch error. It can mean any of the following:
1. The door latch mechanism is broken. Inspect the door latch to ensure it is intact and not broken. Verify the electrical connections are making good contact.
2. The door latch hook (located on the door) is broken or worn. If the latch hook is damaged, it may not allow the door latch to engage and lock properly.
3. The interconnecting wiring between the Central Control Unit (CCU) and the door latch are loose, broken, or not making good contact. The CCU is the main computer for the washer. You will need to remove the top panel of the washer in order to access. Simply remove the retaining screws located in the back of the washer and the panel will slide back, then lift off.
4. Defective CCU. The CCU controls nearly all the functions of the washer, including the door latch. If the CCU fails, the proper lock/unlock signals do not get sent to the latch mechanism.
Determing how to troubleshoot the CCU and Door Latch is in the technical data sheet included with your washer. The tech sheet is located behind the lower toe panel directly below the door. If the tech sheet isn't behind the toe panel, it will be affixed to one of the interior cabinet walls. I do not have the procedure memorized, but there are some tests you can try to determine if the problem is the CCU or latch.
If you determine the latch needs replaced, the following link may assist you:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
The procedures I provided are for Kenmore Elite series front loaders, which are the larger cousing to the HE2. The steps are nearly the same except for how to remove the door gasket from the front facing of the washer. The HE2 models are glued on instead of using a wire hoop (unless yours is a later model and has been modified). You can use a metal putty knife to carefully peel the gasket loose and reseal it when completed. A good appliance gasket cement (found at any appliance parts retailer) will work. You can also use a plumber's sealant. Just make sure you use a pliable rubber cement. Do not use super glue.
Some prefer to try to work through the top of the washer and avoid removing the gasket. This may be possible with the larger top loaders, but the smaller models are usually a bit more difficult to access.
Replacement parts can be purchased on line at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
If you have any questions, please let me know. I hope you find this information helpful.
SOURCE: kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
SOURCE: Kenmore HE2T Front Loading Washer Leaks From Door
there is a dispenser hose that goes in the tub.alot of times a sock or something gets inside that hose.that would cause your trouble.take the boot off the front and look up and left to see that hose.it comes out of the tub pretty easy.
SOURCE: Kenmore HE2t washer - error code 5d
5d is a definitely a the code for a plugged discharge. We removed the lower access panel and discovered a virtual treasure: $12.50 in quarters, nickels, dimes and pennies, a pen, a pencil, collar stays, 10 bobby-pins, 3 barrettes, a elastic headband, a draw string, a box cutter, 3 washers, 3 broken zipper parts, a elastic waist band. Amazing it took all to trigger a 5d error code. Hope this helps!
SOURCE: Kenmore HE2t Error Code F 01 flashes
sF01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
