My 7" tablet only displays infoTMIC on the screen and it wont come on.
I got the tablet from a close relative for a birthday present. I removed it from packaging ,plugged it in and it went to a screen with the icons. I tapped the gallery icon & then pressed power button to go back. The main screen came back up & I powered the tablet down. When I pressed the power button to turn it back on, all that will come on the screen is a logo that says infoTMIC . It will not power completely on. I tried pressing the reset button & nothing changed.
Depending on which version you have please see the following notes:
How To Factory Reset/Recover the systerm On Your Tablet PC(Flytouch 2/SuperPAD 2/Infotmic tablet 2)
1. Press "Power" and "Home" button at the same time, hands off until you see the words on the screen.
2. Select:"wipe data/factory reset" with the "volume" button, and then press "menu" button.
3. Select:"Yes -- delete all user data", and press "menu" button.
4. Wait until you see" Enter erase_cache Data wipe complete" .
5. Press "reset", calibrate it and set the language.
How To Factory Reset/Recover the system On Your Tablet PC(Flytouch 3/Flytouch 4/SuperPAD 3/Infotmic 3)
1. first press the "MENU" key, keep pressing the "MENU" key while you press the "POWER" key, remove your hands when you see "recovery" from the screen.
2. Wait a few seconds until it is done. And then the system will start..
Precautions
A power failure during the firmware writing operation may disable the tablet PC.
* Use a fully charged Battery or dedicated AC Adapter for the firmware update.
* Do not shut off the power during the firmware writing operation
Double-click the Home button and you will see small windows of all the Apps that are currently open. Swipe upwards on one of these windows and it should close. You can continue this process on any other Apps that you wish to close.
To download apps for an Android device, you need to have (or create) a Google account - if you have a Gmail account, it is this same account.
Then, you have to search in your tablet apps for the Google Play app and touch on it. Entering Google Play, sign in using your account and you will be ready to download your apps.
NOTE: to enter your Google Play, you will need to have the Internet connection active and correctly set up in your device.
If you have available at your home, try spraying just a little bit of WB40 in the button and try to move it back to its place depressing it and dragging it back with two matches or two toothpicks.
You could be able to enable presentation mode by pressing the "settings" button on the bootom of your display, next to the power button and the "ctrl" and the rotate button. After you press that, your dell control point manager should pop up and then go to the tablet tab on the left and open it. after that, go to the display tab and you should see an option that allows you to turn your presentation mode on.
