Make sure that the keys are actually locked. If you
attempt to unlock a keypad that is not locked, nothing will happen. Look
on the phone's screen for the key icon that indicates the keypad is
locked. If you try to press any of the keys and the word "Unlock"
appears on the screen, your keypad is definitely locked. If you do not
see the indicator but are unable to use the keypad of your Nokia 6085,
your battery could be dead, so try recharging it and then see if the
keypad works.
Enter the unlock sequence. If the key indicator
appears on your screen, you need to enter a simple sequence of keys to
get the keypad working again. For the Nokia 6085, select Unlock and then
quickly press the * key. If you wait more than 1.5 seconds to press the
* key after selecting Unlock, it will not unfreeze the keys so make
sure you enter the sequence very quickly.
Turn off the automatic keyguard. If you are tired of
having to unfreeze the keys every time you want to make a call, you can
program the Nokia 6085 to always remain unlocked. In the menu, go to
Settings, then select Phone, then select Automatic Keyguard and choose
Off.
There is no specific keypad unlock code my friend, are you sure you have correct samsung behold network unlock code? Actually if your phone already unlocked with correct samsung unlock code that problem will not happened. My sugestion check your unlock code, if your unlock code is the right one you need to reflash your phone.
Same happened to my friend. I unlocked it this way: I called from my
phone and without answering to incoming phone call I started typing numbers on locked out phone and started browsing
through phonebook (without answering). At some point it will say keypad is unlocked.
