Toshiba Satellite M45-S165 Notebook Logo
Anonymous Posted on Sep 18, 2017
Trying to factory restore my toshiba satellite with no luck, i have tried everything that i have read. while pressing F8 there is no option for factory restore. every option on my screen i selected with no luck( safe mode, safe mode with networking, enable vga mode, reboot ect.) not sure what else i can do. blue screen appears and disappears to quickly to read
Matthew Neilson
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 14 Answers
  • Posted on Sep 21, 2017
Matthew Neilson
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
14
Questions
0
Helped
4305
Points
38
Shut off, hold up volume and power till it enters recover mode and try there.
brian williams
Level 3:
Genius:
  • Master 1,980 Answers
brian williams
Master
Level 3:
Genius:
Answers
1980
Questions
9
Helped
740584
Points
5402
Try powering on and hit 0
Dilum Senarath
Level 2:
Sergeant:
  • Toshiba Expert 300 Answers
Dilum Senarath
Toshiba Expert
Level 2:
Sergeant:
Answers
300
Questions
Helped
139218
Points
754
Why you not try to select last known good configuration. it will fix your blue screen error. it is may be a registry error or driver configuration error,but if you can fix disk errors with chkdsk command after select safe mode with command line.
chkdsk c: /f
5 Related Answers
Anonymous
  • 136 Answers
  • Posted on Nov 02, 2008
SOURCE: Toshiba satellite laptop keeps restarting
Is the fan working? It might be overheating.
Or one of the drivers is corrupt, and crashing the computer. The only way to solve that is by remotely (by means of starting from CD with a mobile OS).
dcolvard
Dusty Colvard
  • 65 Answers
  • Posted on Mar 20, 2009
SOURCE: How to remove BIOS memory cache
Since it is a Toshiba Tecra if you are not worried about losing data on the laptop you can try turning on the laptop and start pressing the zero key. It should give you the option to restore your laptop if you haven't deleted the restore partition on the laptop.
Anonymous
  • 20 Answers
  • Posted on Dec 16, 2009
SOURCE: bootmgr is compressed !
Assuming that this is an NTFS drive, you can try starting in safe mode with a DOS prompt. Then use the dos utility to uncompress the target drive.
Another way that is probably more appropriate is to slave the drive into a working PC. This way you can see what is on the drive and copy it to the working PC before you have to FDISK the drive and reinstall the OS (Operating System).
Rich
Anonymous
  • 415 Answers
  • Posted on Feb 12, 2010
SOURCE: i want to restore my toshiba satellite 5205-s503
You will need the restore cds that came with your laptop. Insert the restore cd in your dvd drive and restart your computer. When the message "Press any key to boot from cd" press enter.
Then follow the on screen instructions to restore your computer.
Regards,
nicolasiac
Anonymous
  • 56 Answers
  • Posted on Apr 09, 2010
SOURCE: Laptop shows Toshiba Logo, then Bios option, and then goes black
yes its very possible maybe the one u replaced was faulty?
How to restore a toshiba satellite a135-s2286 notebook without cd?
the f8 function is only to try and remedy boot problems. the recovery option you're getting is to restore if you have already made recovery discs.
if you have a recovery partition on your hard drive you should be able to access it when you boot up. before starting your laptop press and hold 0(zero) key and power on the laptop. once it starts you should get a screen with 3 options then choose option 1 to get back to factory restore.
2answers
Cant restore to factory settings tried 0,f1 and f8 none work
When your Toshiba Satellite laptop goes on the fritz, there are several instances where the best solution is to delete everything and start over. If your system frequently crashes or you can't remove a specific virus, you may want to restore the laptop back to original factory settings. While the easiest way to restore the system is to use the operating system restore disc, it is possible to restore the system without it. Each Satellite laptop also includes a hard drive recovery utility that lets you restore the operating system without the restore disc.
1. Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2. Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3. Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4. Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5. Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6. Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I hope you find it very helpful. Thank you for using fixya.com
Can not factory restore my latoshiba satellite a15 s127 laptop
Hi
try this it may help
when pressing the power on key also press the F8 key a couple of times
some laptops are F10 some are F12 some are zero Keep trying the top row of keys
some laptops even require you to press Alt plus the F8/F10/F12/zero key
hopefully if it works it should take you into the factory restore option
then follow the onscreen instructions
good luck
How do i reset my toshiba satellite back to factory settings
Hi
Press Alt key and F10 key continuesly as it boots up.
If not, then you need run your computer in Safe -mode set up by pressing F8 key (ADVANCE BOOTING OPTIONS). In the advanced options, under system restore there should be the option to restore the factory default installation. Back up your files as i will delete everything. Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help. Regards and thank you for using Fixya !
2helpful
2answers
Factory reset (out of box reset) of toshiba sattellite u305 without disks
If you press F8 just before it boots and you get the restore menu, you are in luck. The partition is still intact.
Follow the on screen prompts to restore the system to "Factory Settings".
Hope that helps.
4helpful
2answers
Reset toshiba satellite A100-TA2 to factory settings
try this link, at appears as if u can download the disks here
http://www.user-guides.co.uk/toshiba/toshibarecovery/toshiba.asp?keywords=toshiba+satellite+a100+ta2+recovery+discs+downloads&recor=121
I want to restore my toshiba satellite 5205-s503 to factory settings. please help. i tried the whole pressing f8 repeatedly thing and there are no options to restore the computer to factory settings.
Regards,
nicolasiac
1helpful
BOOTMGR IS COMPRESSED CANT GET ON F8 REPEATLY HELPP I TRYED EVERYTHNGON MY TOSHIBA SATTLITE P205D S7438PC
Hello.
Saw that you posted again ...
Since you can't access F8, the only options are Repair, Factory Restore and reinstall.
Change your options (usually F1 or F2) to boot from your Windows CD. Run the Repair option.
Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Give this a try:
http://cdgenp01.csd.toshiba.com/content/support/downloads/pma500208010_web.pdf
The last option is a complete install.
Hope this helps.
2answers
Restoring to factory settings
to restore the factory setting you must boot the laptop off of the restore CD it will wipe the drive and reinstall the factory software and drivers just walk through the prompts. holding the f8 key will not restore the laptop to factory settings it just allows for options during windows startup
My Laptop is full of junk and i want to restore it to new setting
No, the F8 button only gives you boot options. Do you have the system recovery disks that came with the laptop?
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
