Sony Bravia Kdl - 60Ex700 60 inch 1080P Led Hd Tv Logo
Eric Posted on Oct 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony bravia screen just stays on black and wont go to picture.
The green light is on and it wont turn off by the remote control, I have to manually turn it off by the power switch on the side of the TV. When turn it on I have to quickly click the power button on the remote so the TV will turn off (red light). No sound or picture, not even the Sony logo when it is turned on.
Back2life Electronics
Level 3:
  • Sony Master 933 Answers
  • Posted on Oct 03, 2012
Sony Master
Level 3:
Answers
933
Questions
6
Helped
274628
Points
2189
It sounds like a main board failure but could be a power supply issue as well. The set will need to be diagnosed
5 Related Answers
Anonymous
  • Posted on Feb 23, 2009
SOURCE: TV won't turn on, red flashing light
Hold The Off Button for 20 sec should make clicking noise switch off at power and on again should be working
Anonymous
  • 10594 Answers
  • Posted on May 17, 2009
SOURCE: Sony KDL-46V3000 Bravia LCD Black screen
Please count Sony KDL-46V3000 standby light blinks as there would be interval of 3 seconds between blinks. Let me know how many times light blinks as its an error code.
Anonymous
  • Posted on Aug 05, 2010
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Anonymous
  • 34 Answers
  • Posted on Jul 28, 2008
SOURCE: Sony Bravia KDL-S40A12U Blank screen
Hello
on your set there is inverter board that is what lights up th backlight on your TV making everything visible that board has went bad.
Thankyou
Anonymous
  • 10594 Answers
  • Posted on Mar 14, 2009
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
1helpful
Im having a problem with our Sony Bravia T.V. When we turn it on the light goes green but the tv stays black, no sound either. Cant turn it off with remote or on TV. The only way is by unplugging it.
Most likely the power supply board needs to be replaced. The fact that both the sound and picture don't work really points to that board.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sony bravia shuts off
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
5helpful
Sony Bravia KDL-46S4100, No Picture No sound
I have a sony bravia kdl 40v 5100 for less than two years and i did not purchased an extended warranty and now my tv is down.
I have no picture, no sound just a black screen when i turn the power on, the power (green) light is lite up and the tv turns off by itself for like less than 30 seconds. I have tried to press as many buttons on the remote control and on the side of the TV to get any message but nothing seem to happen. Any suggestions and solutions? Thanks
I have a sony KDL26L4000 26" and for a unknown reason it wont turn on when using remote i have tried new batteries you have to press up on remote control or 1 on remote control and the green led keeps...
It sounds like the key on the remote is stuck. In your case, if you see the flashing light on the camera screen without pushing any button, then for sure one of the button is stuck.
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
2helpful
2answers
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
