If the unit is under warranty return it to the vendor. If it is out of warranty, it is likely there is damage to the wiring harness is damaged or the connectors between the motherboard and the display are loose.
This would require opening the notebook up and checking the cable. Hopefully the connectors are loose and can be tightened and secured with some neutral cure silicone.
http://www.youtube.com/watch?v=MbieJ2UuZnI
Though skip the removal of the hard drive from its carrier and only go up to the part where he removes the front panel and check the connectors leading to the display. If they are loose, this may be the issue. If not, proceed to where he removes the display. Then open the display. 2 screws behind the rubber plugs on bottom of display and unclip the rest. Remove the display panel and check the cable for cracks or loose connections. You may find the cable required for your model on HP Partsurfer, though many of the cables for this model are no longer available, if not available, the cable will need to be repaired or secured to stop flexing with movement binding with tape can sometimes achieve this. If you don't want to attempt this, take it to your nearest repairer.
SOURCE: SCREEN DOES NOT SHOW HELP HP G60
TRY HOOKING AN EXTERNAL MONITOR TO THE LABTOP IF YOU SYSTEM IS EQUIPED FOR THAT TYPE OF USE., IF YOU DONT HAVE ONE, SEE IF ANYONE YOU KNOW WILL LET YOU BORROW UNTIL YOU CAN SOLVE THE PROBLEM WITH YOUR MONITOR.
ROD
SOURCE: My Hp g60 laptop battery is not working
hai,
i think the problem in battery so try to get new battery and follow the tips to prolong u r battery life through nbbatt blog
SOURCE: MY COMPUTER WON
Take out the battery and try running it on the power adaptor alone. If this works, you have a dead battery. If not there's something more serious wrong in the machine.
SOURCE: HP G60-235DX--LCD screen cracked
yes, there is a way, it is detailed in the HP Service Manual found online
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
start at page 63 of the pdf (refered to as section 4-24 in the manual text) and go from there!
Let me know if you have any questions.
Thanks,
Mike
SOURCE: My HP G60-445DX laptop a damaged LCD screen. Can I
hi yes you can, you can buy a cheap second hand one from ebay, and will take you about an hour to fit
Testimonial: "great.. thanks."
