i mean you can put the disc on the carosell and then it just goes back and forwards, it wont stop when it comes to the disc, then it goes backwards and forwards until it switches its self offi mean you can put the disc on the carosell and then it just goes back and forwards, it wont stop when it comes to the disc, then it goes backwards and forwards until it switches its self off
Hi, Please check door mechanism as explained in chat session and possibly loading belt and/or door switches could be culprit and causing problem. Hope this will help. Thanks.
I Fixed Mine!!! I found that the part that spins and reads the dvds was bad. Luckly i had a spare changer at home to test this. I took it apart and got this info from the part that i replaced.
KHM-2
90AAA
07666HA
514659
Hope this helps
try cleaning the OPTICAL lens directly with a Qtip , gently clean it from any debris , and try again , the procedure shouldnt be hard to open it up , good luck , thanks AJ
I had this problem and I found out that the cable I had bought that fit both the Escient and Sony changer wasnt the right one. I went to Fry's and bought one that said null modem on it and file transfer. Then it found the changer and all started coming together
Hulk SMASH!
