Question about Insignia NS-30HTV 30" TV
Insignia NS-30HTV 30 screen is black on all inputs, and says digital channel signal strength is low, can i fix this?
Screen is just black on all inputs, and the antenna input says digital channel signal strength is low
    New Friend:
  • 3 Answers
You need to get a digital aerial first .then you can sort out any other problems from there
Posted on Oct 03, 2012
4 Suggested Answers
6ya staff
SOURCE:
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: Insignia NS-30HTV "Please Wait"
your tv can be repaired get in contact with a tech to look on your set.you are having a problem with your memory chip or eprom ic.good luck
Posted on Mar 05, 2009
barbu51
Jacques Marin
  • 566 Answers
SOURCE: INSIGNIA NS-30HTV TV will not power on after a/c power failure
It may just be a fuse that is blown. If you take the back cover off and follow the power cord you should be able to find the a.c line fuse, it will be a glass fuse with metal end caps.
A blown fuse will show a broken filament inside or blackened glass. You may also have d.c fuses inside , they will look the same sa the a.c fuse. Their values should be written on the circuit board near the fuses and always on one of the end cap.
something like250V/3A for 3 amps. Hope this will help. Good luck
Posted on Dec 02, 2009
John-INSG
John-INSG
  • 312 Answers
SOURCE: Our Insignia NS-30HTV picture is sort of
In my experience, this indicative of TV tube failure. However, just to be sure, try resetting the TV to factory defaults by entering the onscreen menus, select Picture, then reset. Also, power-cycle your TV (turn it off and unplug for several minutes). More details can be found in the owner's manual. If these steps don't resolve the display issue, you may call 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada to schedule in-home service.
Posted on Mar 18, 2010
I have a Insignia Plasma tv model NS-42P650A11 it is not getting any channels now. Worked then the other day it stopped having any channels, I've unhooked everything for awhile then rehooked everything...
First, I'm not a Insignia representative.
* Check your warranty. call for support.
*** Following for information only.***
* No signal means no usable signal for a specific input on the TV or monitor. Check your cable box. Contact your cable service provider.
* If it's just a monitor and not a multi-function TV that also has a Computer to video input then you need to check the device that's hooked up to the monitor as single function monitor's usually only have one input.
* If this is a TV then you need to go to the TV menu and check the "Input Source" to make sure it's on the input plug your using. (I'm using HDMi-2 on my laptop to TV)
* If it's not on the correct input then there will be a different signal (DVD, VCR, etc.) or none at all (No Signal) if those units are turned off.
* Unplug all devices (to reset) and count to 10. Power up and perform set up to your existing configuration.
* Note; as of Jan 2018 most cable TV are not broadcasting in analog (chan 3) and must use a digital tuner to get signal. Some cable Co. provide converters (for a fee?)
* Check with your service provider for more information.
Aloha, ukeboy57
PS, If you do have a damaged input (or feed) then check your video device for alternative outputs; IE: RCA Vid-Right-Left audio, HDMI, Split video (Y-G-B), VGA, S-plug, etc.
* This your model?; https://www.cnet.com/products/insignia-ns-42p650a11/specs/
* I notice there is no cable input. Try switching to another of inputs;
2 x HDMI input - rear
Composite video input - rear
S-Video input - rear
2 x component video input - rear
Audio line-out
VGA input - rear
2 x audio line-in - rear
Digital audio output (optical)
Aug 09, 2018 | Insignia Televison & Video
How to change input on insignia ns-30 hdtv wiyhout remote
Can you do it with the buttons on the side? Not all features are available that way. another method is with a smartphone smart remote apps can help you too.
Jun 13, 2014 | Insignia NS-30HTV 30" TV
No remote cant change input
There are many places you can buy a remote for $19.99. I searched "Insignia NS-30HTV 30" TV remote purchase" to find these.
Our Insignia NS-30HTV picture is sort of hour-glass shaped on the edges. About 2-3 inches on each side of the picture is missing. How do you fix?
Jan 10, 2010 | Insignia NS-30HTV 30" TV
Dec 02, 2009 | Insignia NS-30HTV 30" TV
Purchased model NS-LCD32 second hand with no
Since you are getting the signal from the satellite, leave the satellite receiver ON and press input on the TV buttons until you get the signal back, wait 2 seconds after pressing the input button. Make sure the TV is on channel 3 if you are using the antenna input.
Let me know if you need further assistance.
Jun 13, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia ns-24ftv won't turn on
I hope it was plugged into a Surge Protector!!!!..
If not, make sure ALL your Breaker Switches are on in the house, RESET THE SURGE PROTECTOR (power bar thingy you got the tv plugged into..).... they will switch off usually to protect the tv...
Mar 19, 2009 | Insignia NS-30HTV 30" TV
Mar 05, 2009 | Insignia NS-30HTV 30" TV
No Power at All
check electromaniac.com and download a service manual for your tv set good luck
Jan 23, 2009 | Insignia NS-30HTV 30" TV
Insignia NS-DXA1 APT remote control doesn't work
Set your TV input to match the input your have your Insigna connected to. Then run the Insignia setup. You are getting a distorted screen because you probably have the Insignia connected to channel 3 and the TV on channel 4.
Dec 30, 2008 | Insignia Digital-to-Analog Converter for...
Insignia NS-30HTV 30" TV Logo
735 people viewed this question
Top Insignia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
