Black toner prints fine, but anytime you print color nothing lines up. I tried the calibration but it doesn't seem to help. Maybe i'm doing the calibration process wrong?
SOURCE: Problem on Toshiba e-studio45
You should probably have a technician look at it and see if there is anything going on with the optics of your copier.
SOURCE: Print driver for Toshiba E-Studio 3511 Copier/Printer for Window
You can go to http://copiers.toshiba.com and download it.
SOURCE: Toshiba E-Studio 3511 Check Color Toner Cartridge
there is a sensor above the coloer developer unit clean it or change the sensor
SOURCE: Toshiba e-studio 3511 has printing issued on one
These copiers have serious toner dust issues. Light copies are usually caused by dust in the optics (the mirrors) and on the laser glass.
Take off the main copy glass and gently clean all the mirrors and scan bulb underneath it - be careful.
If you remove the drum unit and look inside the cavity you took it out of you will probably find a huge toner mess. the laser glass is situated in this cavity and needs to be cleaned - just clean whatever you can see...
SOURCE: I am trying to print from my HP laptop to a
try this
http://copiers.toshiba.com/downloads/KB/file_uploads/6029/es4511-v122130-w2kxpvis-pcl6.zip
if u using usb port try the network cable by using ip
