Question about Frigidaire FAD704TDP Dehumidifier
What does code AS mean - seems to be working fine.
  • Official Brand Answer
  • 4,342 Answers
Hello marilu scheck - Typically error code AS indicates that a sensor failed has occurred on the dehumidifier. You may want to contact your manufacturer and then a professional they suggest to have it repaired.
Posted on Oct 04, 2012
6ya staff
SOURCE:
AMB 10000E Red light on the right of the control screen is on. What does this mean?
i have this problem too...red light, no explaination. did you find a solution?
May 24, 2012 | Amcor AL-10000E Portable Air Conditioner
Bionaire BDQ25 QUIETech Dehumidifier, manual all the lights are on and shows a "E1" problem, we have unplugged and plugged back - it does not work
Since Bioaire is stingy with their Owners Manuals, it's hard to tell you what the error code means. However, if you have misplaced your Owners Manual, you can contact the company"s Customer Service Dept for a replacement, as well as what the Error Code means and how to solve it. In CANADA and the USA Call 1-888-324-9907
Jul 08, 2011 | Bionaire BDQ25 Dehumidifier
Kenmore Dehumidifier 129-25803, Pump System malfunction
I also have a Kenmore pump system 129-25803 but I do not have the manual. I have tried to find one online but to no luck. I also called the Sears Parts & Service and they do not have a listing for this type of dehumidifier. Just wondering if you have a manual you could share? Please email me at taylor005@eastlink.ca
Jul 26, 2010 | Kenmore Dehumidifiers
Dehumidifier does not remove water from the air.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 31, 2010 | Maytag M7DH45B2A Dehumidifier
Everything seems to work but it is not collecting any water. Two years old, FDL25P11. Has worked perfectly until now, 25 qts every two days
Apparently the room humidity was too low (we were in a long cold dry spell) now that the rains have returned the machine works fine.
john
Dec 14, 2009 | Frigidaire Dehumidifiers
Everything seems to run fine, just hasn't pulled a drop of water
remove the back airfilter, and touch the tubes while the unit is running, if nice and cold, all is well, there just isnt any moisture there. but if compressor is running and tubes are warm , means freon/coolant has leaked out
Jul 22, 2009 | LG LHD65EBL Dehumidifier
Fan motor stopped working, replacement went out too!
I would look for another outlet for you to plug it in before you start anything elaborate. I assume you've done this already but spin the motor/blade. If it spins and there is little or no play in the shaft or blades causing a blade to bind up the mechanical part seems ok.
Now if you have a volt meter First check the motor for voltage, Then if you have voltage, compare it to the rating on the motor. Usually a voltage within 10% is ok. Next test resistance on the wires of the motor any resistance and the winding is probably okay. If not then the motor is out again. If you have lost voltage the control board is your next part to test. No voltage out to the motor there on the board plug and the board is the problem Power there woudl mean the motor has too high a resistance and Id check the resistance on a differant known good motor before replacing it. just so you know where you started.
Mar 10, 2009 | Goldstar DH3010B Dehumidifier
Unit overflows the condensate container with water.
To find out if it is the switch, unplug the unit and disconnect one or both of the wire to the switch.Plug back in and see if it quits filling.
If so it is most likely the switch is bad.
Jun 12, 2008 | Maytag M3DH30B2A Dehumidifier
Frigidaire FAD704TDP Dehumidifier Logo
441 people viewed this question
Top Frigidaire Dehumidifiers Experts
Alan Chouinard
Andrew Taylor
Andrew Taylor
STEVE
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
