Question about Zhone 1518-A1-NA Wireless Broadband Router - 54 Mbps 1 x ADSL Network WAN, 4 x 10/100Base-TX Network...
1518-A! router how to find my ip address
  • Zhone Master
  • 32,281 Answers
Click Start on your computer then Run and type cmd then press Enter.
When the DOS command box opens then type ipconfig and press Enter The computer will the display the IP address that was issued to your computer BUT if the IP address is 0.0.0.0 then your router did not issue an IP address to your computer and you need to repair the network connection.
Posted on Oct 04, 2012
6ya staff
SOURCE:
What is the Username and Password for a Cavalier provded Zhone 1518-A1 Modem Router?
If the Zhone 1518-A1 was provided by Cavalier, then the address is:
192.168.1.1
Default Username: admin
Default Password: c@v@l13r (all lowercase)
This information was valid as of 01/17/2013
Jan 17, 2013 | Zhone 1518-A1-NA Wireless Broadband Router...
Only you know your SSID( username)and Security Key(password). You can RESET the device to default settings by pushing and holding the reset button for 30 seconds or so and release. That will reset to default setting. Then you can reconfigure the SSID and Security Key, You may want to write down the info for future use. This may help: http://www.zhone.com/products/1518-A1/
I need the default username and password for the Zhone 1518-A1 dsl router i cant find it or figure it out please help
192.168.1.1
This information was valiad as of 01/17/2013
Aug 16, 2011 | Zhone 1518-A1-NA Wireless Broadband Router...
I have a Zhone ADSL2+ 4 Port Wireless Bridge/Router, model number 1518-A1-UK-0MA. it as working perfectly until one day when i turned it ON, only the ADSL LED is lit, no other LEDs are on, nor the power...
Please use the following steps:
1. Remove the router and connect it directly from the pc to the modem.
2. Power cycle: turn the modem off and then the computer for 30 seconds, then turn them both back on, modem first.
3. Check you internet connection to see if it working.
4. If it working, connect the router back up. If it not working contact your ISP for dsl support.
5. Once the router is connected, release/renew the ip address. Go to the dos command type ipconfig/release press enter. Then type ipconfig/renew. Check your ip address, you shouldn't get an ip address starting with 169. If you do, this mean you have a problem with the router getting an ip address.
6. Check you internet connection after the release/renew
Jun 10, 2011 | Zhone 1518-A1-NA Wireless Broadband Router...
When i try to install my Linksys wireless G, it ask for a password. I don't know it and it won't let me proceed!
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Nov 04, 2010 | Linksys Wireless-G Broadband Router
I am trying to set up a new printer to a Linksys router model no WRT300 Ver 2.0. I have lost my IP no and also my Network Security Key, Is there any way to retreive these nos Gordon Stephens
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Step 2:
If you forgot the router's IP address you can:
NOTE
Step 3:
Aug 21, 2010 | Linksys Wireless-G WRT54G Router
How to find router fully ip address?
if your PC still working and connecting to the internet thru this router, then open command prmpt, enter "ipconfig" and read the ip address of the default gateway. at most simple home networks, that is your router.
Jun 06, 2009 | EnGenius EOC-3220+ (EOC3220PLUS)
LINKSYS ROUTER
You need to know the ip address of your dvr. It might have a factory set ip address or a dynamic ip address from the router. You can then use this ip address to access your dvr.
If your dvr has a static ip, that static ip should be in the same range as the router's ip address so that the router can communicate with the dvr.
Mar 12, 2008 | Linksys Wireless-G WRT54G Router
Zhone 1518-A1-NA Wireless Broadband Router - 54 Mbps 1 x ADSL Network WAN, 4 x 10/100Base-TX Network... Logo
137 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
